throttle body removal 94 accord?
Old Jan 17, 2010 | 10:17 AM
Greatness's Avatar
Default throttle body removal 94 accord?
So I removed all the screws for the throttle body. I think its stuck or something. Any suggestions?????
I appreciate the help you guys give me.
Old Jan 17, 2010 | 12:23 PM
mayfieldfour's Avatar
Default Re: throttle body removal 94 accord?
Tap on it with a rubber mallet. If its never been removed, it could just be stuck as you stated. A rubber mallet or hammer (use a thick cloth as a deadener) should jar it
Old Jan 17, 2010 | 01:00 PM
Dannyvho's Avatar
x2 And don't forget to use a new gasket when re-installing.
Old Jan 18, 2010 | 06:43 AM
Greatness's Avatar
thanks
Old Jan 18, 2010 | 09:06 AM
nus_dogg's Avatar
And scrap the old gasket off the intake mani for a better seal.
Old Feb 3, 2014 | 10:16 PM
Mikzize's Avatar
By chance , do you know the diameter of the throttle body of a f22b1? Is it 70mm?
Old Feb 3, 2014 | 11:06 PM
holmesnmanny's Avatar
I don't think any Honda throttle body is that big, even the type S is only 62 while the h22a is 60 ...not sure about the f22b1
Old Feb 4, 2014 | 02:17 AM
hondamark35's Avatar
pretty sure they're 60mm. i think most F-series are the same.
Old Feb 4, 2014 | 09:10 AM
Fitz Williams's Avatar
10 Year Member
I think the F22B1 is around 56mm. A B18B1 is about 60 and also uses a larger diameter intake tube.
Old Feb 4, 2014 | 12:03 PM
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/throttle-body-size-2496331/
you must be thinking D-series...
Old Feb 5, 2014 | 03:38 AM
10 Year Member
I pulled two from the salvage yard and measured them. The B18B used a larger intake tube (mine won't fit) and had less metal on the inside of the throttle body as well. The same gasket would fit either TB, but the F22B1 gasket would be sticking out into the opening on a B18B TB and plenum. It looked like what I would expect form a bored F22B1 except that the site that fits onto the intake tube is slightly larger. And I checked the block to make sure which motor it came from.
ThrowdownPerfor
Feb 23, 2011 09:01 AM
chiefb26
22
Apr 18, 2008 05:32 PM
concept11253
May 20, 2006 11:57 PM
