Cigarette lighter problem
Old Jan 17, 2010 | 08:16 AM
Steve LeB's Avatar
Default Cigarette lighter problem
97 accord besides the lighter hanging out of the console it won't charge the gps unit when plugged in. When I put the test light to the center and sides of the lighter the light comes on showing power. any suggestions.
Old Jan 17, 2010 | 08:40 AM
19Accord97's Avatar
Default Re: Cigarette lighter problem
Take out the trim bezel around it and look for a loose connection/ground.
Old Jan 17, 2010 | 11:39 AM
beauc's Avatar
New User
Icon2 Re: Cigarette lighter problem
I got exactly the same problem last week! 96 Accord. Lighter became very loose because I pulled the plug too hard the other day. Casting can be pulled out up to this level (see picture). Now I have to push it in and hold it every time in order to get power. How to fix this?
Old Jan 17, 2010 | 11:51 AM
19Accord97's Avatar
You need to remove the trim bezel around it.
There is a clip that attaches to the cig lighter (you cant see until you take the trim off) that is the ground. More than likely it is unplugged and when you push it in, it plugs into it again.
Old Jan 17, 2010 | 02:41 PM
beauc's Avatar
New User
Thanks much for your reply. I removed the trim bezel around it. There was a loose metal tubing in there (connecting to the power source I assume). However, I could not secure the casting (in picture above) to the metal tubing. Where is the "clip"?
Old Jan 17, 2010 | 02:54 PM
19Accord97's Avatar
You may just have to put a new cig lighter in there which you can get from any auto store and will a breeze if you can solder. When you remove the trim bezel completly, you have to unhook the clock, hazard button, and then there should be a wire or two that are connected to the cigarette lighter.
Old Jan 17, 2010 | 04:26 PM
TheMuffinMan's Avatar
He knows where you live!
The OEM part is cheap to replace.
Just buy it from TAS Auto and swap it out
Old Jan 17, 2010 | 05:15 PM
CuteAccord's Avatar
Had the exact same problem, but I found the fix about 2 years ago. Take out of the radio and then from behind you can grab a hold of the lighter and "screw" it back in, you must reach back there. It takes a couple of tries but it will eventually screw back in.
Old Jan 20, 2010 | 05:43 AM
beauc's Avatar
New User
Icon6 Re: Cigarette lighter problem
I fixed it! "Screwing" was the key. I opened the trim bezel/dash panel again, held the metal tubing, and screwed the casting back until it was secure. Now the lighter is working as if it were new. Thanks for all your help!
Tokyo_Hippie
Aug 14, 2017 05:36 PM
John Tully
Jun 17, 2013 04:25 AM
soccer guy
Apr 5, 2011 10:05 PM
batookee
Oct 17, 2004 06:41 AM
JDM-FREAK
Oct 6, 2002 10:11 PM
