Tires affecting dyno numbers?
Old Sep 4, 2002 | 04:47 PM
B2FiNiTY's Avatar
Default Tires affecting dyno numbers?
How much will changing tires affect dyno numbers? I.E. from 195-55-15 to 205-50-15.
Old Sep 4, 2002 | 04:51 PM
uNF$@#!'s Avatar
Default Re: Tires affecting dyno numbers? (B2FiNiTY)
friction + extra weight = more rotational mass.
you planning to dyno?
Old Sep 4, 2002 | 04:53 PM
B2FiNiTY's Avatar
Default Re: Tires affecting dyno numbers? (Soup ****)
Yeah...I might wanna hold off on the tires until after the dyno day,
Cosworth's Avatar
so negligible that it's nothing to worry about.
It'd be one thing if your wheels + tires weighed 40lbs each.
Old Sep 4, 2002 | 05:05 PM
disordeR's Avatar
tire pressure affect it?
Old Sep 4, 2002 | 05:11 PM
B2FiNiTY's Avatar
Default Re: Tires affecting dyno numbers? (disordeR)
Tire pressure will. I believe the higher the pressure the higher the numbers.
Old Sep 4, 2002 | 05:13 PM
Cosworth's Avatar
wth?!
Old Sep 4, 2002 | 05:15 PM
B2FiNiTY's Avatar
Default Re: Tires affecting dyno numbers? (Cosworth)
The key is less resistance.
Old Sep 4, 2002 | 05:16 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
That's probably only true if you go from like 5psi to 35psi. Any reasonable psi would probably be unnoticeable.
Old Sep 4, 2002 | 05:20 PM
B2FiNiTY's Avatar
Default Re: Tires affecting dyno numbers? (ActiveAero Ninja Edition)
True. But does anyone have info on tire sizes or weights?
Old Sep 4, 2002 | 05:41 PM
jond's Avatar
You can figure the diameter here:
http://robrobinette.com/tire_diameter.htm
The 205s will be somewhat smaller
Old Sep 4, 2002 | 05:45 PM
jond's Avatar
Default Re: Tires affecting dyno numbers? (jond)
This doesn't have the same widths, but you can see that going from 185 to 195 is between 2-3lbs.
Thus around 8whp you would lose with the 205s?
http://www.miata.net/faq/tire_weights.html
[Modified by jond, 9:45 PM 9/4/2002]
Old Sep 4, 2002 | 05:57 PM
rainmanEK's Avatar
big strong guy
Default Re: Tires affecting dyno numbers? (4MATIC)
yah its weird..but when ever I get some new tires. I feel a loss of power
its because the extra grip!!!
Old Sep 4, 2002 | 06:11 PM
TypeR 599's Avatar
D...no matter what you're still going to dyno low
Old Sep 4, 2002 | 06:40 PM
Driver's Avatar
So if I dynoed at 170.4 with the 205's I should be close to 178 whp with the 195's ??? Or am I dreaming
Old Sep 5, 2002 | 05:32 AM
B2FiNiTY's Avatar
Default Re: Tires affecting dyno numbers? (01-1214)
I'll just dyno with the new tires. Numbers aren't really all that important.
Old Sep 5, 2002 | 06:40 AM
Flux's Avatar
You guys are Dyno ******...
Old Sep 5, 2002 | 07:14 AM
newt2's Avatar
INSERT TITLE HERE
25 Year Member
Community Builder
Size won't matter but weight will.
Dynos can calculate your effective gear ratio from the rpm count on your engine and the rpm of the roller.
Old Sep 5, 2002 | 07:18 AM
B2FiNiTY's Avatar
Default Re: Tires affecting dyno numbers? (newt2)
Too late now...going to change out the tires today. Maybe I'll put down less than stock numbers
Old Sep 5, 2002 | 08:04 AM
B2FiNiTY's Avatar
The tires are 3 lbs more than stock. What's the formula for calculating how much hp difference?
FastechAccord
May 13, 2018 05:43 PM
Steeve_Civic
Aug 30, 2014 02:56 PM
pho:20
Feb 22, 2006 09:34 PM
DeusXmachina
Jun 17, 2004 01:35 PM
