B18b turbo wont idle....
got a 99 civic si put a b18b turbo running a chipped p06 runs fine just dosent idle dies a stops sometimes idles really low....what could it be... no check engine light either ......
HELP!!!!!!
HELP!!!!!!
yea, I have a 89 civic hatch with a dohc zc swap, and my did the same thing, mine was the idle air control valve, just took it off and cleaned it with brake cleaner and let it dry out, and now it's fine
no prob bro, and if that doesn't work amd you think it's a vacuum leak one way is to buy some sea foam cause it makes ur car smoke, and check ur lines while it's running and if you see smoke coming out of one there you go!
dsmarefaster
May 15, 2005 03:55 PM
