Distributor question/issue
Old Jan 16, 2010 | 06:01 PM
Lemmingz's Avatar
Default Distributor question/issue
So I went to change my cap and rotor today on my car and when I pulled of the distributor cover I saw this... Is this bad or normal wear and tear?
Old Jan 17, 2010 | 04:06 AM
Lemmingz's Avatar
Default Re: Distributor question/issue
damn nothin?
Old Jan 17, 2010 | 05:53 AM
00Red_SiR's Avatar
All Motor Mentor
looks fairly normal to me. How do the terminals inside the cap look and how old are the parts?
Old Jan 17, 2010 | 06:57 AM
Lemmingz's Avatar
I'm not 100% on the age of the parts, probably a few years. I attached a picture of the cap
Old Jan 17, 2010 | 07:10 AM
00Red_SiR's Avatar
All Motor Mentor
I'd change them out.
Old Jan 17, 2010 | 07:47 AM
Lemmingz's Avatar
Yea I swapped the cap and rotor yesterday, it was my first time doing it though and I was just making sure that was from wear and not another issue. Thanks for the help man
Old Jan 17, 2010 | 12:58 PM
luispizarro25's Avatar
i remember when i did this i was looking forever for that little screw... i had to push the car for a while... good times...lol
Old Jan 17, 2010 | 01:03 PM
Lemmingz's Avatar
rofl, yea it was a fun learning experience
Old Jan 19, 2010 | 03:37 PM
jdmturboitr's Avatar
Just curious, did you have a problem wit your car? Like did it not start or where u just doing maintenance?
Old Jan 19, 2010 | 04:17 PM
forsakenriceboy86's Avatar
that rotor and cap looks pretty normal, i've seen worse.!
Old Jan 20, 2010 | 08:37 AM
Lemmingz's Avatar
Well the car has been feeling a little slugish lately so I'm trying to go through and freshin everything up. So other then that I would say just maintenance
Old Jan 20, 2010 | 09:04 AM
****....I'm thowin a code 15 and can't figure out WTF is wrong wit it and it dnt start
Old Jan 20, 2010 | 10:12 AM
99cx's Avatar
Hmmm code 15...
never experienced it before but does you engine turn over?
or do you have no spark and no power?
check the bly/ylw wire, between the ecu plugs...
it may have been damaged when you were working on it...
or any other of the wires.
Also check you Main Relay, do you here the clicks from it?
I have also been told to check your Ignitor?
Lastly if you can try and install another dizzy just to check
one from a friend or if you have one laying around.
Good luck.
Old Jan 20, 2010 | 10:57 AM
It does crank over....has fuel....no spark. And I say it has no spark cuz when it gets cranked I pull off a plug wire from dist. Cap too see if there's spark jumpin and there's not.
Old Jan 21, 2010 | 12:05 AM
Problem solved......case of cold budwieser and 3 hrs later, wiring shorted out a fuse...... Car is on da road again!!!!!
Thanx fellas!!!!!!!!!!
ludecrasy87
Apr 27, 2007 09:41 AM
br1ev8
Dec 11, 2005 09:25 AM
harwood
Mar 16, 2005 07:01 PM
civicracer1993
Nov 6, 2002 07:07 PM
GRM Scott
Mar 1, 2002 04:41 PM
