Camber Correction without a camber kit?
Old Sep 4, 2002 | 04:04 PM
iam7head's Avatar
Default Camber Correction without a camber kit?
is there such thing? i heard they offer such service in some local places?
something to do with washer? Around 100 bucks for all four wheels.
Old Sep 4, 2002 | 04:38 PM
H23 Power's Avatar
Default Re: Camber Correction without a camber kit? (iam7head)
you can user the washer trick in the rear (actually i'm not sure if it works on 6th gens or not)
but i doubt you could do it on all 4, i certainly wouldn't pay anyone to do it, its really easy, unless that includes checking the camber specs and such
Old Sep 4, 2002 | 08:36 PM
Gen4-5Door's Avatar
Just don't let anyone bend your control arms. I have heard of people doing that for camber change! Boneheads!
Old Sep 4, 2002 | 11:15 PM
iam7head's Avatar
Default Re: Camber Correction without a camber kit? (Gen4-5Door)
i already order the eibach sportline for 2inch drop front and back.
with the 2inch drop, what is the negative camber degree?
just dont wanna fu_k up my new tires.(kumho 711)
Camber kit needed?
Old Sep 4, 2002 | 11:35 PM
GimpyAccord's Avatar
heh, mine were "bent" .. but only because looong ago when i was into 18'z there WAS no such thing as a camber kit. i didnt pay for it tho, i had a friend cut (witha torch) and bend them slightly.
My rears i did with washers though. I agree, don't do what I did now that you actually have a CHOICE. I had to goto the junkyard and digup stock front suspension when I put the steelies back on 2 years ago.
camber shot when it was on 18's:
[Modified by GimpyAccord, 8:40 AM 9/5/2002]
Old Sep 5, 2002 | 04:21 AM
90H22's Avatar
Default Re: Camber Correction without a camber kit? (GimpyAccord)
So basically you joined Honda-Tech two years ago. Is that what you're saying?
Old Sep 5, 2002 | 05:41 AM
jweller's Avatar
Default Re: Camber Correction without a camber kit? (Two1Accord)
This does NOT work for 6th gens
Old Sep 5, 2002 | 06:32 AM
haha no, 2 years ago I woke up one morning and looked in the garage and saw BS. Sold the rims, system, and whatever else i thought was gay. Never looked back... i would like some Honda OEM alloys though!! People hang on to those like their.. emmm jewels
Old Sep 6, 2002 | 12:32 AM
iam7head's Avatar
i know this is getting lame but if i lower my accord(6G 4cyl) with sportline for 2 inch do u recommend me to spend the extra cash for camber thing?
i do have a 17inch rims right now
Old Sep 9, 2002 | 07:48 PM
90H22's Avatar
If you really need some I've got a set. 1990 EX OEM Alloys. Two with good tires, all wheels in pretty good condition. If you want 'em make a decent offer.
Old Sep 10, 2002 | 04:38 PM
urbanlegend21's Avatar
New User
get a camber kit, get a camber kit, get a camber kit, get a camber kit......... the only thing negative camber is good for is on race cars, but also do not forget about your toe, that is what really wears your tires down
if you can stay above -2 degrees camber you will be alright
Old Sep 10, 2002 | 06:57 PM
iam7head's Avatar
me
2inch drop=2degree negative?
1.5inch drop=1.5degree negative?
Old Sep 11, 2002 | 09:29 AM
greensleeper's Avatar
me
no
Old Sep 11, 2002 | 02:46 PM
iam7head's Avatar
Default Re: Camber Correction without a camber kit? (greensleeper)
em...so can anyone tell me the degree if i got a 1.5inch drop?
measure..measure
Old Sep 11, 2002 | 03:01 PM
H23 Power's Avatar
i think the standard is .5" = 1 degree of camber
Old Sep 11, 2002 | 03:31 PM
New User
Default Re: Camber Correction without a camber kit? (F23 Power)
it also depends on wheel/tire size
Old Sep 11, 2002 | 11:05 PM
ekk's Avatar
ekk
Default Re: Camber Correction without a camber kit? (urbanlegend21)
um not all cars will have same negative camber even with same suspension setup .. best thing to do is take the car to an alignment place and have print out a sheet for u telling u all the info .. most places should be free
siguy9900
16
May 13, 2008 07:05 PM
doubleshotz
Suspension & Brakes
Nov 2, 2007 05:01 PM
BJA86
11
Sep 2, 2007 01:00 PM
b18LS
Suspension & Brakes
Apr 18, 2007 06:05 AM
itsJDMyo
13
Jan 7, 2005 10:40 AM
