PVC valve ..problem when attempted to replace
Old Sep 4, 2002 | 03:53 PM
ragejed's Avatar
Default PCV valve ..problem when attempted to replace
So I ordered a buncha parts for my tuneup. I tried to replaced the PCV valve. I also got a new rubber garment for it so it seals good (dunno how good the old one was)
I popped out the PCV outa the lil case it sits in. that went fine.So i tried to take the PCV off the hose...it wouldnt budge. So i tried to take off the rubber garment outa the lil box...that wouldnt move either. so i tried to carfully persway it to come out with a screwdriver...BAD IDEA! the damn thing popped it self into the PCV box!. So i jacked up the car, hoping I can just unbolt the box and fix it.. I took out the 2 bolts that hold it in directly. But I guess there are more that I am missing. . Question is. How do i remove the box? and how do I get the pvc valve to get outa the hose?
I have a helms manual. I couldnt find this in the book tho. If anyone can point me to a page that would be great Any other help would be wonderfull.
BTW: its a 98 teg gsr
[Modified by ragejed, 12:56 AM 9/6/2002]
Old Sep 5, 2002 | 12:09 AM
WiggiE's Avatar
New User
Default Re: PVC valve ..problem when attempted to replace (ragejed)
ttt....good question
Old Sep 5, 2002 | 05:55 AM
jeebusm3's Avatar
Default Re: PVC valve ..problem when attempted to replace (WiggiE)
bump...i wanna know too.
Old Sep 5, 2002 | 11:17 AM
ragejed's Avatar
Default Re: PVC valve ..problem when attempted to replace (gtravsr)
Bump...cause I still wanna know, bahahha...OMG , something hit my screen in my window... anyway. Ima go whack at my car, Ill let u know how it goes.
Old Sep 5, 2002 | 01:30 PM
ragejed's Avatar
Alright, I got the bracket out that is in the way...Question tho...If I pop out the box that the PCV valve goes into...will oil poor onto me?
Old Sep 5, 2002 | 02:04 PM
ebelp's Avatar
BTW, what are the symptoms of a bad PCV valve??
[Modified by ebelp, 12:27 PM 9/6/2002]
Old Sep 5, 2002 | 02:40 PM
jeebusm3's Avatar
Default Re: PVC valve ..problem when attempted to replace (ebelp)
i'm gonna give this another bump but damn....it's PCV guys, not PVC!
Old Sep 5, 2002 | 03:43 PM
ALF's Avatar
ALF
BTW, what are the symptoms of a bad PVC valve??
Changing mine cured all my fluctuating idle problems.
Old Sep 5, 2002 | 03:55 PM
ragejed's Avatar
Default Re: PVC valve ..problem when attempted to replace (ALF)
Fixed to PCV
Anyway, I got the box out and all. You need to undo the braket thats over it, and that holds up the IM. I need to order a part from acura. (Rubber O-Ring) mine looks a lil sctretched (better safe then sorry)
Ya, I have idleing probs too. But Im sure this huge tuneup im doin should fix all this. Oh ya, my old pcv valve was al lil stuck. Not soo free-moving like the new one.
[Modified by ragejed, 12:58 AM 9/6/2002]
D16W9
Honda Civic (2001 - 2005)
Dec 9, 2014 02:15 AM
EgHatchy96
Jul 25, 2013 10:44 PM
jmdinn
Nov 4, 2012 07:41 PM
SpoolinEK9
May 19, 2005 02:51 PM
