Gas Gauge Going All The Way To FULL!
Ok so I removed my cluster in my 96 Accord to install some white face gauges and Blue LED Turn signals which came out amazing I must add. I put the gas gauge at the position it was at when I took it apart which was just a hair over half a tank.... I put everything back together carefully not forgetting any screws and parts. But when I turned my key on The gas gauge shot way past the full line and is just stuck there... I took the face off again repositioned the gauge in the correct spot again... and tryed again... same thing. I even tryed pushing the needle all the way to empty, Plugged it in... Same thing needle shot all the way up past the full mark. I beyond stumped at this point.
Any advice from HondaTech?.... Please Help Thank you ahead of time.
