00 si check engine light
Old Sep 4, 2002 | 03:05 PM
havalilsi's Avatar
Default 00 si check engine light
i bought a 00 si about 9 months ago then later i realized i did'nt have a check engine light. i just put in a lamp and the light stays on. is there any possible way to check for codes to try to pin point the problem, or is there some other way to try to go about finding the problem
Old Sep 4, 2002 | 03:21 PM
HXMan's Avatar
Default Re: 00 si check engine light (havalilsi)
Yes, by the ECU there is a green plug. By the green plug you will find a blue plug looking thing with 2 wires going into it, but they go nowhere. You need to put something like a paperclip between the connectors to "short" it. Then, turn the key to the ignition position, and the check engine light will blink in a code. Long Blinks = 10, 20, 30, etc. Short blinks mean 1, 2, 3, etc.
So, 4 long blinks, and 5 short blinks would be code 45.
Old Sep 4, 2002 | 03:25 PM
salbaje's Avatar
http://www.c-speedracing.com/faq/06.html
Old Sep 4, 2002 | 04:01 PM
havalilsi's Avatar
Default Re: 00 si check engine light (salbaje)
you guys are great. i went outside to check the codes and got a 41 code. on the link that i got there wasn't any mention of 00 civic so i hope these codes will apply
Old Sep 4, 2002 | 04:07 PM
havalilsi's Avatar
btw what is an oxygen sensor and do they go bad often
Old Sep 4, 2002 | 04:14 PM
salbaje's Avatar
they dont go out often but they do go out randomly especially maybe when you are running too rich and clogs it.
ethos0518
Aug 13, 2011 07:36 AM
turbo18coupe
Apr 14, 2007 06:49 PM
SmogKing
Aug 3, 2006 12:48 PM
cogs200
Feb 5, 2006 08:35 AM
badasssi
Jan 20, 2003 10:30 PM
