Suspension & Brakes Theory, alignment, spring rates....
dc2 brakes on 1997 civic hx
Old Jan 15, 2010 | 08:56 AM
adam00's Avatar
Default dc2 brakes on 1997 civic hx
I have a 97 hx that needs new wheels bearing so i thought i would just upgrade to integra brakes all around but im not sure what parts i need. So far i know i need an integra master cylinder, brake booster, prop valve, front knuckles, rotors, calipers, e brake cable and rear disc setup but im confused on what I need to make the front integra brakes bolt up.
Old Jan 15, 2010 | 11:01 AM
phunhaus's Avatar
Default Re: dc2 brakes on 1997 civic hx
They bolt right up.
Old Jan 17, 2010 | 02:08 PM
Psychoteen101's Avatar
Why would you need a different master cylinder and brake booster? The stock ones will be just fine. The proportioning valves should be the only thing you need to change under the hood.
Old Jan 18, 2010 | 07:42 PM
300whpej's Avatar
the mc wont hurt, but id resist messing with the brake booster at all costs unless you really know what youre up against
Old Jan 18, 2010 | 09:18 PM
Unless the master cylinder is bad, its a waste of money and labor. Then you have to worry about bench bleeding. And if you dont do that right, it might screw up the seals in the brand new master you installed.
Old Jan 27, 2010 | 04:41 PM
adam00's Avatar
do i use the ek upper and lower front control arms and the integra spindals?
joprez
May 7, 2013 02:54 PM
verycleanhatch
Suspension & Brakes
Sep 4, 2009 01:34 PM
Walterronny
12
Apr 16, 2006 08:01 AM
streetsweeper
Suspension & Brakes
Oct 11, 2005 05:00 PM
bruvaman
Jul 9, 2002 07:19 PM
