Which transmission mate with f23a1?
Old Jan 14, 2010 | 09:03 PM
accord99power's Avatar
Default Which transmission mate with f23a1?
Looking for a solid transmission that could have an lsd to that mates with my f23a1. researched abunch, I see some ftob adapters. However, i thought i seen h23 mates without much to do on accord chassis. Please help.
Old Jan 15, 2010 | 03:33 AM
hondamark35's Avatar
Default Re: Which transmission mate with f23a1?
as i understand any H-series trans should work fine. i don't know which would have come from the factory with LSD.
i don't think an F2B apapter would do you much good in an accord chassis. that's kinda working backwards, more complicated instead of less complicated.
Old Jan 15, 2010 | 05:45 AM
i tried researching but came up with very little, thankyou for the reply, do you know of any posts with the swap?
Old Jan 15, 2010 | 06:07 AM
nus_dogg's Avatar
M2B4 LSD, H23, and T2T4(F20B) LSD trans will all do by using your stock accord tranny mount.
Old Jan 15, 2010 | 09:06 AM
good info man. I seen another post sayin they perfer the longer gears on the f23 though, i don't plan on going over 120 ever, should i use stock f23 and find an lsd or go with shorter gearing h23 etc?
Old Jan 15, 2010 | 09:19 AM
i forgot you were boosted... i'm thinking if you can find an LSD to fit the stock trans. you'll be good. you've got a relatively low redline and a torquey motor, long gears are what you want. well, assuming this is a daily driver and not a dedicated strip car...
Old Jan 15, 2010 | 12:42 PM
yes this is my dd, thankyou for the advice man!
Old Mar 28, 2020 | 02:48 PM
amiri golden's Avatar
Post Re: Which transmission mate with f23a1?
hello i am swaping a auto to manual in my 1999 Honda accord 2.3L vtec it has a f23a1 engine. i was wondering what 5 speed tranny is compatible with it. on a budget. please help
Old Mar 28, 2020 | 08:01 PM
folsom@hondatech.com
Feb 22, 2008 08:26 PM
H23_Del Sol
Jun 3, 2006 07:36 PM
93ludeSi
Mar 20, 2003 05:49 PM
93ludeSi
Mar 18, 2003 10:43 PM
