Gas line for N20 wet kit
Is better to tap in the gas supply line for the fitting or ive seen some kind of fitting you can get on the fuel filter i believe, and not have to cut into any hoses?? btw its a b16
I always cut the rubber line from filter to fuel rail and put in a T with hose barb on the ends and whatever you need for the top for line to solenoid. Make sure you make the fittings tight so no leaks.
for sure..thanks. ya thats how i did it last time for my k20. i just hope that t fitting supplied with the kit also fits this b series fuel line...it should i mean its for every 4 cyl.
KarmaJosh
Feb 24, 2010 09:34 AM
god.loves.ugly
Nov 4, 2007 08:39 AM
