WHY ARE MY BRAKE LIGHTS NOT LIGHTING UP???
Old Jan 14, 2010 | 12:56 PM
804tuned's Avatar
Icon2 WHY ARE MY BRAKE LIGHTS NOT LIGHTING UP???
i have a 96 integra gsr and the brake lights dont light up..i already checked the back light fuse,the brake sensor,and the bulbs...is there something i'm missing??? thanx 804....
Old Jan 14, 2010 | 01:15 PM
zedron's Avatar
Default Re: WHY ARE MY BRAKE LIGHTS NOT LIGHTING UP???
Is the brake sensor you are referring to the one located near the pedal?
Old Jan 14, 2010 | 01:16 PM
804tuned's Avatar
yes..it's above the brake pedal...
Old Jan 14, 2010 | 01:26 PM
zedron's Avatar
Ok, How did you check the switch? Did you try replacing it with a known working one or did you bypass it?
Old Jan 14, 2010 | 01:29 PM
804tuned's Avatar
i replaced it with another sensor....
Old Jan 14, 2010 | 01:56 PM
zedron's Avatar
Just saw your post in the Integra thread which mentions you replaced it.
Hmmm, Im stuck man. If I think of anything i will let you know.
Old Jan 14, 2010 | 07:11 PM
ohsnapzafingcu's Avatar
I serve phở for my babies
the same problem stumped me for a long time, it turned out there was a plug under my plastics by my driver quarter panel and one of the wires was loose from the plug, so we had to rig it up to stay..
what we did was pull the switch out so the lights are on constantly, get a test wire and look for the wire that runs along side the driver side, under the plastics, and we kept pushing the pointy end of the test light through the wire to see if if was getting power, then we slowly went about a foot at a time down the wire til we found the culprit..
Old Jan 14, 2010 | 07:46 PM
804tuned's Avatar
Icon6 Re: WHY ARE MY BRAKE LIGHTS NOT LIGHTING UP???
thanx 4 the help man..i'll keep you posted on the outcome..
chighizola9
Jul 20, 2013 01:46 PM
disboiflaco
Mar 14, 2011 05:45 PM
804tuned
Suspension & Brakes
Jan 18, 2010 01:33 PM
guero2craze
Jul 28, 2008 05:30 PM
PREACHERBREW
Jun 5, 2008 01:12 PM
