ls turbo questions
Old Jan 13, 2010 | 01:46 PM
LS-turboner's Avatar
Default ls turbo questions
so im swapping a obd2 b18b1 into a EF dx trim hatch. im getting a SI harness thats already wired for MPFI, its obdo, so what are my options as far as obd0 to obd2? jumper harness or backdate the intake mani and sensors? and ecu?, i also plan to turbo this motor, so what is a affordable program to tune on, i dont have money for hondata or aem ems, so is chrome really sufficient? reliable?
Old Jan 13, 2010 | 05:44 PM
MrDomino's Avatar
Default Re: ls turbo questions
Crome would be sufficient but after just spending the last week or so tuning my car (from scratch) I can tell you that the Demon board + Neptune is probably your best bet. Crome isn't a bad program but still leaves a lot to be desired.
Old Jan 13, 2010 | 06:13 PM
mtber's Avatar
1. Run an obd0 to obd1 ecu harness
2. Wire your obd2 distributor into the vehicle.
3. Use an obd1 ecu
Read http://www.phearable.net/tech/efibeginnerguide.html
Old Jan 13, 2010 | 06:50 PM
thanks, that post was to the point. could i run a obd1 dizzy? because i dont have one anyways. what else differs from obd1 to obd2?
Old Dec 20, 2020 | 11:54 PM
turbolsvreno79's Avatar
I was told if you run an obd1 ecu, you need an obd1 dissy. For the tdc sensor to communicate properly.
teggyman267
Feb 13, 2010 07:00 AM
trevek10
Sep 17, 2009 05:28 PM
vtecftw
Aug 11, 2007 11:15 AM
2wheelhunter
Jun 4, 2007 04:18 PM
97DGreenEx
Oct 13, 2006 06:21 PM
