Honda/Acura Ready to ship Performance Parts at FIFA Racing
Exhaust Parts
Aftermarket exhaust parts are intended to replace the factory fitted exhaust components in order to gain a performance increase. Some aftermarket parts are designed to improve the look and sound of the car, rather than its performance. In general, the goal of aftermarket exhaust systems is to increase the engine power by reducing the back pressure of the factory exhaust system. Frequently a side effect of a free-flowing exhaust system is the increased engine sound, which is desirable to some people. Aftermarket exhaust parts can also be a styling upgrade by change the visible parts of the exhaust like the exhaust tips.
Depending on your vehicle, we carry different exhaust systems and components. Catbacks, Turbobacks, Uppipes, Downpipes, Mufflers, Tips, Midpipes, Cat Delete Pipes, and more are just to name a few products in our Exhaust System category. We carry exhaust components from: 5Zigen, Supersprint, Meistercraft, Tubi, Greddy, HKS, Tanabe, Jubily, TechArt, JIC, Comptech, APS, Agency Power, RSR, Perrin, Espelir, Milltek, Invidia, GHL, JBA, Fabspeed, Borla, B&B, Neuspeed, and more. If you don't see the exact high performance exhaust your looking for, please contact us at 1-888-553-3432. We'd be happy to help you find the perfect exhaust for your needs.
HKS Hi Power Axle Back Exhaust Honda Civic EX/DX/LX 01-03$374.99 Click here for best prices
HKS Hi Power Rear Section Exhaust Honda Fit 2007$319.99 Click here for best prices
HKS Sport Dual Axle Back Exhaust Honda Accord 3.0 V6 98-02$534.99 Click here for best prices
Tenzo R Bolt-on Type 2 Exhaust System Honda Accord 94-97$256.99 Click here for best prices
Tenzo R Bolt-on Type 2 Exhaust System Honda Accord 98-01$256.99 Click here for best prices
Tenzo R Bolt-on Type 2 Exhaust System Honda Civic 01+$256.99 Click here for best prices
Berk Technology Cat Delete Pipe w/ Built-in O2 CEL Fix Honda S2000 02-07$112.99 Click here for best prices
Skunk2 Racing 70mm S2000 Test Pipe $131.25 Click here for best prices
Without a boost controller, air pressure is fed from the charge air (compressed side) of the turbocharger directly to the wastegate actuator via a vacuum hose. This air pressure can come from anywhere on the intake after the turbo, including after the throttle body, though that is less common. This air pressure pushes against the force of a spring located in the wastegate actuator to allow the wastegate to open and bypass exhaust gas from reaching the turbine wheel. In this simple configuration, the spring's springrate and preload determine how much boost pressure the system will achieve. Springs are classified by the boost pressure they typically achieve, such as a "7 psi spring" that will allow the turbocharger to reach equilibrium at approximately 7 psi.
AEM Tru-Boost Gauge-Type Controller $335.58 Click here for best prices
.jpg)
Agency Power Manual Boost Control Kit $104.99 Click here for best prices
Blitz SBC i-Color Boost Controller Spec R $887.99 Click here for best prices
Greddy Profec B Spec II Boost Controller Silver $431.99 Click here for best prices
FIFA Racing carries ECU Tuning Components for Honda applications. We carry AEM EMS ECU's, Autronic SMC Plug-in ECU, and more.
AEM EMS ECU Honda Civic DX/LX/EX M/T Only 01-05 $2,405.67 Click here for best prices
AEM EMS ECU Honda Civic 88-91 $2,231.25 Click here for best prices
AEM EMS ECU+UEGO Honda Civic DX, LX, EX, SI (M/T Only) 01-05$2,773.10 Click here for best prices
AEM EMS ECU+UEGO Honda S2000 M/T Only 00-05 $2,506.68 Click here for best prices
Thanks all for the support
Interested?
Send a PM or Chat with us online at
www.fifracing.com
Naiomy Nieves
sales@fifaracing.com
1-888-553-FIFA
.jpg)
Interested?
www.fifracing.com
Naiomy Nieves
1-888-553-FIFA
