Performance General Performance oriented Parts (Ex: Camshafts, Electronics, Air Intakes, Exhausts, complete engines)
Autotech WAVETRAC Differential(LSD): The latest in LSD technology
Old May 7, 2008 | 03:17 PM
ExospeedAMcrx's Avatar
Default Autotech WAVETRAC Differential(LSD): The latest in LSD technology
<FONT SIZE="4">Autotech Driveline WAVETRAC Limited Slip Differential </FONT>
[I]$935.00
LIFETIME WARRANTY!!! Manufactured in the USA.
Available for:
GSR/B18C
B16/LS
K20/K24 – RSX/TSX
H22/ - Prelude
Innovative:
Patent pending Wavetrac® design automatically improves grip in low traction conditions. This feature is truly innovative and unlike any other torque biasing diff design.
Customizable:
If desired, the diff's behavior can be altered in the field to suit your needs.
Superior Materials and Construction:
9310 steel gears run in case-hardened billet steel bodies. ARP® fasteners used throughout.
Limited LIFETIME Warranty:
All Wavetrac® differentials include a transferable, Limited Lifetime Warranty.
<U>The Wavetrac differential in detail:</U>
Enhanced No-Load Bias Ratio via its Wave Design Center Pack
One of the known shortcomings of a typical torque biasing differential is its loss of drive (behaving much like an open diff) under zero or near-zero torque conditions (for example, when there is 'no-load' applied through the drivetrain, either at vehicle stationary and/or transition from engine driving vehicle to engine braking and back).
The Wavetrac® differential uses a patent pending design to improve grip in low traction conditions. Precisely engineered, converging / diverging wave profiles are placed on one side gear and its mating preload hub. As the two side gears rotate relative to each other, each wave surface climbs the other, causing them to move apart. This imparts an increased normal force through the side gears, increasing the bias ratio as a function of load. This increase occurs automatically only when conditions find it necessary, and it 'reverts' back to its nominal bias ratio quickly and seamlessly, maintaining optimal drivability and performance at all times. It's like having two differentials in one: you get the benefit of a higher bias ratio when needed without detriment to the car's handling.
Interchangeable Friction Plates Provide Controlled Bias
Here's something else you won't find in any other design:
The Wavetrac® diff's behavior can be altered in the field to suit your needs. It comes standard with carbon-fiber bias plates for the best all around performance. Interchangeable plates using materials with different friction coefficients to fine-tune the bias ratio are sold separately.
These friction plates provide a mechanism to tune the response of the differential as a function of applied torque load. The applied torque load manifests itself as an axial load from the differential pinions into the housing. This axial force is then considered a normal force into the friction plate, and as a function of the effective coefficient of friction, will provide a resistive torque to the rotational motion of the differential pinions. The resistive torque will add to the resistance of relative rotation of all components within the differential. The resistive force, however, is non-uniform since it is a function of the axial load from the differential pinions. The unbalance of the resistive torque will manifest as non-uniform energy absorption within the differential causing a bias ratio.
Superior Design, Materials, and Construction
Designed from a clean sheet, the new Wavetrac® Differential brings current gear technology to the market. Internally, its gear tooth forms are optimized for strength and improved oil film retention over competitive designs. Our gear package is smaller, reducing overall mass, yet is more durable. Attention was also paid to the side gear/axle interface, putting as much material thickness as possible in this critical area - most important when power levels get high.
Each Wavetrac® Differential is crafted from the highest quality materials available. The internal gears are made from high strength 9310 alloy steel. The diff bodies are machined from case hardened steel billet. To complete the package, every Wavetrac® differential is built exclusively using high quality, high strength fasteners from ARP®, the world leader in fastener technology.
Modified by ExospeedAMcrx at 2:14 PM 6/17/2008
Old May 8, 2008 | 05:04 PM
Default Re: Autotech WAVETRAC Differential(LSD): The latest in LSD technology (ExospeedAMcrx)
good to go. ready to ship.
Old May 12, 2008 | 10:35 AM
Modified by ExospeedAMcrx at 12:03 AM 5/13/2008
Old May 12, 2008 | 11:03 PM
ttt
Old May 16, 2008 | 07:49 AM
TurblowR's Avatar
Default Re: (ExospeedAMcrx)
wow thats a nice looking diff! I was reading up on it at www.autotechdriveline.com and it looks promising.
Old May 16, 2008 | 09:41 AM
Default Re: (TurblowR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurblowR &raquo;</TD></TR><TR><TD CLASS="quote">wow thats a nice looking diff! I was reading up on it at www.autotechdriveline.com and it looks promising.
</TD></TR></TABLE>yup, we've been selling them left and right. we stocked up on the k-ser, b16 and gsr.
Great thing is, theyre made in the US. and Autotech has a Lifetime warranty on them too.
Old May 20, 2008 | 01:16 PM
819turbo's Avatar
do you ship to canada? let me know by email poopdog819@hotmail.com
Old May 20, 2008 | 04:53 PM
EFinawesomeman's Avatar
Default Re: (819turbo)
Do you have one that will fit an S1 cable transmission? By the way Exospeed is the buisness! I love your guys' products.
Old May 20, 2008 | 08:40 PM
untuned's Avatar
can you give me a priced shipped to L6C 2X7 markham ontario Canada for a gsr unit
Thanks
Old May 21, 2008 | 09:20 AM
thanks for the orders. check your pm guys for those quotes and questions.
Old May 25, 2008 | 07:53 PM
red02s2k's Avatar
bump for when i get some money
Old Jun 19, 2008 | 08:56 PM
Default Re: (red02s2k)
ttt
Old Jun 23, 2008 | 10:49 PM
Autotech for the best warranty and customer service for LSD!!
Old Jun 24, 2008 | 10:32 PM
lemon_juice's Avatar
anything for dseries?
Old Oct 27, 2008 | 04:42 PM
Default Re: (lemon_juice)
ttt
Old Mar 15, 2009 | 08:37 PM
EG_DAO's Avatar
Life Warnety for sure
Old Jan 18, 2010 | 11:07 AM
eaddagwan's Avatar
bump from the dead. i sent you guys a pm
vinuneuro
Transmission & Drivetrain
19
Apr 16, 2009 01:06 PM
mhewitt
15
Jan 14, 2009 11:58 AM
EduardoDC5
18
Nov 25, 2008 08:16 AM
Wavetrac
19
Oct 31, 2008 02:12 PM
stonedheckler
Oct 1, 2006 01:59 PM
