Nason paint?
Old Jan 13, 2010 | 12:08 PM
B16CRXVTEC's Avatar
Default Nason paint?
hey i just bought 3 qts. of Nason Paint. not sure how good this paint is? has anyone in here used that brand? if so how is the quality on them?
any advice on what type/brand of primer i should get? any info will help. thankx.
Old Jan 13, 2010 | 12:55 PM
redboost10's Avatar
Default Re: Nason paint?
we just resprayed the engine bay with nason paint. it was the cheapest base that industrial finishes has, its just base. gonna get covered with clear so dont skimp out on the clear is the way we look at it.
as for the primer, are you spraying it on bare metal or a previous layer of base/primer?
Old Jan 13, 2010 | 01:43 PM
B16CRXVTEC's Avatar
thanks for the reply... i will be spraying 3 coats of Nason and 2 clear coats? will that work? or should i spray more clear coat?
as for the primer it will be previous layer of base/primer.
Old Jan 13, 2010 | 01:48 PM
redboost10's Avatar
if your not stripping it down to bare metal...which should be avoided anyways if could, you can just use some urethane primer, i used nason primer as well. we shot about 3 coats of base and 3 or 4 coats of clear because were **** and wanted some depth. just remember, whatever the primer looks like is what your finish will look like. spend lots of time sanding the primer before layind down the base...unless you plan to wetsand the base as well.
Old Jan 13, 2010 | 01:57 PM
B16CRXVTEC's Avatar
thanks for the advice and information! really really helpful.
that leads me to another question.
Like a NEWBIE i didnt do my research before sanding down my fenders. the fenders are sanded down to bare metal. i used a Krylon Primer. the name of the krylon was Rust Tough? should i resand it down and spray it with a different type of primer?
Old Jan 13, 2010 | 02:01 PM
redboost10's Avatar
for bare metal, epoxy primer is the best choice. the oem honda primer is very very effective at preventing rust, thats why its best to keep the very bottom layer of primer if possible
Old Jan 13, 2010 | 02:10 PM
B16CRXVTEC's Avatar
ohic. so should i resand my fenders and respray it with a different primer? or will the KRYLON RUST TOUGH will do?
Old Jan 13, 2010 | 02:15 PM
redboost10's Avatar
i have never used that primer...maybe someone else will chime in on that for you. sorry cant help there
Old Jan 15, 2010 | 06:06 PM
precisionsc54's Avatar
is it out of a rattlecan? If so strip it off and use epoxy.
Old Jan 16, 2010 | 01:00 AM
prelude1897's Avatar
Hell yea....
raider1qaz
Paint and Body
Oct 18, 2013 04:01 PM
crxsir23
Paint and Body
Feb 24, 2010 06:12 PM
choua01
Paint and Body
Feb 23, 2009 05:51 PM
drumminforev
Dec 8, 2006 10:10 AM
firstgenrex
Sep 12, 2003 08:49 PM
