please help
Old Sep 4, 2002 | 12:18 PM
Trinity's Avatar
Default please help
ok today i went to leave and my car wouldn't start at all. it won't turn over, i changed my ignitor like 5 mins ago and no change at all. does anyone know what it could be, i have tortex saying its a fuel pump relay or main relay, any other suggestions
Old Sep 4, 2002 | 12:21 PM
Hcivic88's Avatar
Default Re: please help (Trinity)
u flashing any codes?
edit: check for spark, pull a plug out and ground the bottom of it and watch for spark, if you're getting spark its gotta be something with the fuel.
are the plugs wet? dry?
[Modified by Hcivic88, 1:22 PM 9/4/2002]
Old Sep 4, 2002 | 12:35 PM
Trinity's Avatar
Default Re: please help (Hcivic88)
no codes, and i can't check for spark by myself unless someone knows a secret. i didn't pull the plugs, didn't want to until i check for sparl. is there anyway to check without someone sitting in the car cranking it while you touch the wire to a ground
Old Sep 4, 2002 | 12:40 PM
Mr Furball's Avatar
also when you check the spark you can just take the end of the plug from the dizzy and hold it close to where it plugs in and see if a spark jumps from there.
hope this helps
Old Sep 4, 2002 | 12:49 PM
Trinity's Avatar
Default Re: please help (FURBALL B-16)
thanks hun but i already new that, that is where i check for spark.
i just don't know what to do i have to have this car for work seeig as how my other car i just bought isn't running yet
Old Sep 4, 2002 | 01:12 PM
Trinity's Avatar
ok isn't a fuel issue because i am hearing the pump whir when i turn the key to the 2nd mark
Old Sep 4, 2002 | 01:15 PM
MrTodd's Avatar
Nuts. That sucks big time. I'm guessing it worked just fine the day before, right?
What exactly does it do when you put the key in, and try to start it? Any clicking at all?
Who knows, maybe you just left the lights on or something??? Or perhaps a ground came loose? Maybe a wire unplugged out of the starter(happened to me one time )?
Good luck!
Old Sep 4, 2002 | 01:30 PM
Trinity's Avatar
Default Re: please help (MrTodd)
yep no problems at all, that would atleast help me a little. when i put the key in and turn it everything comes on like normal. radio, guage cluster all that. i try to crank it and it cranks it just won't catch. if it was a dead battery it would click, its not clicking. its trying to start.
Old Sep 4, 2002 | 01:34 PM
wronghand's Avatar
Sounds like the coil. If you just replaced the ignitor and you hear the fuel pump come on when you turn the key then about all that leaves is the coil.
Old Sep 4, 2002 | 01:41 PM
Trinity's Avatar
Default Re: please help (wronghand)
ok well i guess i will go buy one of those and put it in tonight. i was thinking maybe cap and rotor but that usually gives you warning signs, not just take a crap
Old Sep 4, 2002 | 01:47 PM
wronghand's Avatar
Since you will have them off anyway, check the cap and rotor for wear.
Old Sep 4, 2002 | 01:49 PM
Trinity's Avatar
yeah i was gonna replace that anywayz, i should have a new dizzy then just about.
thanks for everyones help.
Old Sep 4, 2002 | 02:45 PM
Phatwhippin_CRX's Avatar
Your distributor won't always act up before it takes a ****..... usually it does, but not all the time. I went through 2 of them and one time it just went apeshit and died. The other time I could tell it was gonna happen...... either way, a tune-up can't be bad for the smurf. If it's not the dizzy, the main relay could be the source....
Old Sep 4, 2002 | 06:01 PM
Trinity's Avatar
Default Re: please help (Phatwhippin_CRX)
ok fixed ignitor, didn't help found out that wire #3 wasn't getting spark. change cap and rotor - fixed it. all better, the smurf runs fine. thanks everyone for the help
Crossbreeder
Aug 16, 2010 05:52 AM
jdmekfouR
Sep 9, 2009 03:57 PM
Noo_Ish_mee
11
Jul 13, 2009 09:47 AM
DelSlowmo
61
Feb 12, 2009 07:50 PM
skata89
May 21, 2006 03:32 PM
