H22, H23 head differences... few easy questions...
Old Jan 12, 2010 | 07:58 PM
H23_del_soul's Avatar
Default H22, H23 head differences... few easy questions...
Looking to get a few things for my H23 and want to know what all will swap onto the H22 head once I finally save up the money to do the swap. I have the H23 swap in my del sol and feel like I need the Vtec, so am H22 head swap is DEFINITELY in the cards before the end of the year. I am having some issues with the idle, and a weird miss at low RPM and at WOT and hoping that while I add some parts to the motor I will either inadvertently either fix the issue, or find out what the issue is. I am thinking cam gears so I can go zero degrees for the moment, and maybe cams. Would be nice to swap out the timing belt at the same time. A quick little heads up and a shopping list for what all I will need for the head swap would be nice also if anyone has one and on the last note, are there any good build threads or just plain how to's on the head swap would be KICK ***! More on the miss in a later thread. Also, I have an aeromotive AFPR I want to install this weekend, can I still run my stock fuel rail, or do I have to swap rails, and will the rails interchange on the 22 and the 23?
Old Jan 13, 2010 | 10:43 AM
Default Re: H22, H23 head differences... few easy questions...
Nothing?!? Not one person knows any of the answers to these questions?!? I find that impossible.....come on guys....
Old Jan 15, 2010 | 09:33 AM
JDM_CD7's Avatar
Search tool is your friend....... in your case an enemy
Old Jan 15, 2010 | 08:06 PM
searching for vtec, h22 or h23 in giving more results than I was looking for...
Old Jan 15, 2010 | 08:54 PM
Mike95lude's Avatar
This thread should be a good place to get started:
https://honda-tech.com/forums/showth...hlight=H23VTEC
If you decide to tackle this, you will want to have your H23VTEC built by an experienced engine builder. Your H23 bottom end is probably due for a rebuild. You will need good engine management (eCtune, Neptune, or Hondata) and an OBD1 Integra/Civic VTEC ECU (P28, P72, P30, etc.)
Old Jan 16, 2010 | 12:05 PM
Thanks mike
Old Jan 19, 2010 | 12:26 PM
Are the dizzy caps and rotors and everything interchangeable? I am thinking of buying this to clear up my idle issues and don't want to have to replace it again once I make the swap. http://cgi.ebay.com/ebaymotors/HONDA...Q5fAccessories
H23_del_soul
12
Jan 15, 2010 09:37 AM
4thgenpro
Jun 27, 2006 10:31 PM
mattf22b1
May 24, 2006 08:38 AM
hondaguyef
23
Apr 25, 2004 03:40 PM
Smurfylude
Jul 21, 2002 11:05 PM
