b16 wiring question
I am going to purchase a b16a2 for my 95 dx do i need to use the wiring harness off of my old engine and put it on my new one so the plugs will match up drivers side and passenger side? also my harness doesn't have vtec so where can i buy the pins to insert into the plug? how much? also i need a good shop to buy the engine im in the miami area im in the millitary so i am far from my old stomping grounds of oregon where i knew where to go thanks for the help
order your motor from http://www.hondamotorsonline.com
and the question about wiring, i'm sure where you buy the pins but i would suggest that you buy a 94 del sol vtec engine harness and then add your vtec wires to your in dash harness. it will just look cleaner that way.
hatch b16a guy
Jul 15, 2007 08:25 PM
bambbrose
12
Nov 18, 2004 09:51 AM
