What Head Bolts/Studs Should I Be Using For This Combo ?
Old Jan 12, 2010 | 03:08 PM
35r'DHyBriD's Avatar
Default What Head Bolts/Studs Should I Be Using For This Combo ?
I have a B16 Bottom-end with a GSR Head and seem to have a slight oil leak with my new set-up coming from the dizzy corner between the block and head ... not alot at all i would say about a tablespoon a week and really i think it only happens at high RPM but I'm thinking due to the fact that this set-up is new and don't have Vtec wired up as I was trying to work all the under hood bugs out first before I went to the wiring. Thanks in advanced Guys !!
Old Jan 12, 2010 | 06:07 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: What Head Bolts/Studs Should I Be Using For This Combo ?
Always match the studs/bolts to the block you're using.
Old Jan 13, 2010 | 08:45 AM
Thanks man .. ARP will be getting a call from me soon for some studs
FrostByte27
Dec 11, 2009 12:50 PM
h22squeaker
Apr 4, 2005 08:20 AM
K-Drum
Aug 14, 2004 08:51 PM
civcexcoupeblack
Mar 23, 2003 01:22 PM
baonest1
Oct 17, 2002 06:29 PM
