Suspension & Brakes Theory, alignment, spring rates....
Inner and outter tie rod ???
Old Jan 12, 2010 | 01:42 PM
EgK2o09's Avatar
Default Inner and outter tie rod ???
Would a bad inner or outter tie rod cause binding, when the wheels turn one way? i have a 94 accord and when i take right corners @ a decent speed i something feels like its binding. It sounded like the axle was just starting to go and now im getting a binding when cornering right. I appreciate anyones help...
Old Jan 12, 2010 | 02:12 PM
civicsmoke's Avatar
Default Re: Inner and outter tie rod ???
its possible, jack up the wheel, grab at 3 and 9 and see if theres play(tie rods), also grab at 12 and 6 while your at it(balljoint), do this to both front wheels. It could be a lower control arm bushing as well. i had the same thing going on and it was my front lca bushing. btw make sure the steering wheel is locked.
Old Jan 12, 2010 | 03:00 PM
Tyson's Avatar
no, i dont see how its possible 2 balljoints could bind... they can have a lot of play and still be in need of replacement. but i dont see how they can bind.
probably your axle.
Old Jan 12, 2010 | 05:11 PM
EgK2o09's Avatar
yea i hear what ya saying... thanks for the help
Old Feb 14, 2010 | 07:23 AM
graffini's Avatar
i have the same problem but mine started after i replaced one side of the car not the other
Thunderchild
May 29, 2019 07:01 PM
Northernlightz
Apr 2, 2015 07:15 PM
delljoey
Dec 4, 2012 05:30 PM
$amGD3
Suspension & Brakes
Jun 27, 2011 10:20 AM
Propulsion
Aug 3, 2002 08:52 AM
