Turbo'ed Civic; Tell me what Im missing
1992 Honda Civic Dx 1.5L SOHC MT D15B7 Non-Vtec
PO6 Chipped ECU (just have basemap made for my setup for now)
440cc Injectors (Lucas)
Ebay Modified Intake manifold (70% more volume than stock intake)
2.5in Exhaust system
Fully Rebuilt Head
Vitara Turbo Pistons 8:1 compression (not 9:1)
Custom Downpipe
T3/T4 Turbocharger
Compressor Specs :
3" Compressor Inlet
3.000" or 76.20mm Major
1.988" or 50.50mm Minor
Compressor .50 A.R.
Compressor 57 Trim
M24 / T4 Compressor Housing
Turbine Specs :
T3 Type Turbine
11 Blade Type
Turbine .64 A.R.
Turbine 76 Trim
2.560 " or 65.04mm Major
2.204 " or 56.00mm Minor
Manual Turbo Boost controller
38mm External Turbo Wastegate (custom dump pipe)
Turbo Sequential Blow Off Valve (It Can Hold Up To 1200HP Or 25 PSI Of Boost Pressure)
28"x7"x2.5" Front Mount Intercooler/2.5in piping
Adjustable FPR 0-140psi (going to run 38psi to start)
Stock Fuel pump (31-38psi with regulator vacuum attached and 40-47psi without regulator vacuum
Braided Oil Feed & Return Lines
Oil Catch Can
90amp Alternator
10.2mm spark plug wires
NGKBKR7E-11 Plugs (2steps colder) gapped-.026
Adjustable cam gear (set at stock)
58mm throttle body (stock)
Yellow top battery
All sensors are in OEM and working condition and have not been modified in any way.
Fully Rebuilt Head
Custom Downpipe
T3/T4 Turbocharger
Compressor Specs :
3" Compressor Inlet
Compressor .50 A.R.
Compressor 57 Trim
Turbine Specs :
T3 Type Turbine
11 Blade Type
Turbine .64 A.R.
Turbine 76 Trim
Oil Catch Can
90amp Alternator
Yellow top battery
dont really need an aftermarket fpr or the cam gear. ditch the stock pump for a walbro 255. says you have vitaras but i didnt see that you have rods or not. stock rods or eagles or what?
how much hp you want?
The cam gear is mainly for a nice look. The FPR is mainly for my well being. I like to know whats going on with everything, guess its my OCD. The fuel pump will be put in next month when I get the new tank. Rods are stock but brand new. Got them for free!!! Im not completely set on a HP goal yet, but 275-310hp sounds great to me. My main goal when building this monster, was to make sure it was built with all new parts and to be sure it was solid. Just wanted to build something I could have some fun in. Im not even sure what my setup would do as is!?!?
rocko5845
Jan 16, 2010 06:45 PM
rocko5845
13
Jan 13, 2010 10:03 AM
