gsr head on b16 block
Old Jan 12, 2010 | 08:13 AM
negusjuda's Avatar
Default gsr head on b16 block
so i have a b16 long block and a pnp gsr head and was looking at the compression calculator to see what compression this would yield. it comes out to 10.8:1 comp would this be a good set up with skunk2 tuner stage 1 cams seem like by the numbers it should be very close to a ctr motor and should yield the same numbers if not more anyone do this set up before
Old Jan 12, 2010 | 08:20 AM
delsolproblems's Avatar
Default Re: gsr head on b16 block
It wouldn't have the top end or redline of the CTR since you're running a shorter block and rods.
Old Jan 12, 2010 | 12:23 PM
negusjuda's Avatar
huh umm if im not mistaken the b16 has almost a perfect r/s ratio if anything it will have more of a top end then a ctr the ctr is a destroked b18 they did that to get a higher r/s ratio and better reving capabilities
negusjuda's Avatar
what it wont have is the displacement of a ctr
Old Jan 12, 2010 | 12:55 PM
It'll have similar displacement but different crankshaft positions where the rod and crank pin arm form a 90 degree angle. This will change the effective powerband somewhat. Weight aside, longer rods decrease friction, center the combustion force more precisely onto the crank arm and tend to move the powerband upwards. The "perfect" stroke/rod ratio depends on what rpm's you want the motor to make max power at and what torque vs. HP levels you want or need for your vehicle. How much power you gain compared to the weight you add with a taller block is one of the more important factors to consider with rod length. As you increase rod length, the benefits are eventually cancelled out by both vehicle and rotating assembly weight. The lighter everything is, the longer the rod you can use without decreasing power.
Old Jan 12, 2010 | 01:14 PM
88Hatchy's Avatar
It will work fine. I would use bigger cams.
Why does this same question keep popping up?
Old Jan 12, 2010 | 01:31 PM
aeenox's Avatar
My motor is set up like that. It came like that when I bought the car I'm planning on getting a b16 head doe cause my gsr head went out cause I never got my valves adjusted. The motor was running fine and mines red line was 8400 rpm.
Old Jan 12, 2010 | 01:54 PM
negusjuda's Avatar
bigger cams on 10.8:1 compression why when most after market cams call for that compression and more
Old Jan 12, 2010 | 01:56 PM
negusjuda's Avatar
what you want me to run stage 3 cams lol 10.8:1 is basically stock compression and i didnt know this question came up before sorry i would like to see dyno sheets of this set up 170 whp would be nice with this setup
Old Jan 12, 2010 | 06:55 PM
88Hatchy's Avatar
sure they do
/sarcasm
Old Jan 14, 2010 | 11:33 AM
negusjuda's Avatar
so should i go with the gsr head or stick with the b16 head and which do you guys think will make more power granted the gsr head is slightly ported and the b16 head is stock
BlueRex1020
Aug 22, 2008 08:53 AM
allm0t0rsir
Dec 1, 2006 11:01 AM
skittersk8er
Mar 15, 2006 10:39 AM
94delsol
Aug 23, 2004 11:41 PM
JDM92CX
Jun 2, 2003 09:09 AM
