All Motor EG ITR swapped. ? about ITBs Opinions Welcome!
Old Jan 12, 2010 | 07:12 AM
boostntofu's Avatar
Default All Motor EG ITR swapped. ? about ITBs Opinions Welcome!
Hey guys! I got a 93 si with an ITR swap, Rocket Motorsports M22 cams/valvetrain, stock bottom end. Skunk2 fuel rail, eriks racing fpr, walbro fuel pump, and 440cc injectors, Tri-Y, and a velocity stack style intake. Runes obd2 distributor jumper harness and hondata full tune. Its already pretty quick but im looking for another 50hp N/a Do you think if I got some ITB's this could be done with tuning? what problems would I run into as a daily driver with ITB's?
Already got 215 wheel horsepower dyno'd
All comments welcome, let me know what you think.
Old Jan 12, 2010 | 07:31 AM
2.0L_of_fun's Avatar
Default Re: All Motor EG ITR swapped. ? about ITBs Opinions Welcome!
the step to get your 50whp is huge compare what you did. i think the only solution is to jump up the compression of your engine. because the itb's work great with high compression. plus they are complex to tune right on the spot (espatially if you got cheap one).
Old Jan 12, 2010 | 07:35 AM
boostntofu's Avatar
I can get the tune done pretty cost effectively, the ITBS are expensive, and isnt the ITR compression already like 11.6?
Old Jan 12, 2010 | 07:42 AM
all depend of which year. i think the highest compression ratio is in the 98-00 itr spec-r.
is somebody able to corfirm.
Old Jan 12, 2010 | 07:46 AM
zGo's Avatar
zGo
ITB's have to be tuned very frequently. Just an FYI that it's not a one time thing.
Old Jan 12, 2010 | 08:05 AM
4piston's Avatar
There is certainly power to be gained with ITBs that are sized properly, but you are already making good power for the setup. You could see good gains in the midrange, and maybe a few up top. 50 is not gonna happen.
Either way, you'll be happy with the sound and throttle response. Well worth the money.
Old Jan 12, 2010 | 08:36 AM
92TypeR's Avatar
FSAE
Since you know the power you want, browse through the All-Motor Dyno Thread and look at the various setups and what they make in terms of power. Compare that to your goal, and you can get a general understanding of what type of modifications will get you there.
FYI, you will not make 250whp on a 1.8L on pump-gas. You will need to consider displacement options.
Old Jan 12, 2010 | 08:42 AM
boostntofu's Avatar
Thanks 92typeR I will check this out. I know im already make good numbers with what I have but I should be able to do better
Old Jan 12, 2010 | 07:15 PM
Allmotor-R's Avatar
ITr compression is 11.1 ..
Old Jan 12, 2010 | 07:18 PM
Allmotor-R's Avatar
I agree !!! 250whp on 1.8 even with race gas would be hard to touch unless you running like 15.1 comp lol ..you can always bore your block to 2l stroke it and do 12.1 with itbs youll be in that range! i see 230's on 1.8 with itbs and 12.1 with good tune!!! i made 215 whp on 11.1 with skunk2 stg 2s with no itbs stock Manifold/TB
Old Jan 12, 2010 | 08:44 PM
q16racer's Avatar
not true.
________
MIYOSHI PLANT (MAZDA) SPECIFICATIONS
Old Jan 13, 2010 | 05:15 AM
Teamdiesel's Avatar
I am guessing that your 215 was on a Dynopack? Even with a 2.0lt setup it's going to be hard to get close to 250whp without major modifications and upgrades. A simple 2.0lt setup is not going to cut it at all . Oh wait...you can go to Church's Dynopack and made ungodly power lol
Old Jan 13, 2010 | 05:24 AM
92civiceg9gsr's Avatar
Some good headwork will get you closer to your goal. CCcylinderheads, RLZ
Old Jan 14, 2010 | 05:34 PM
boostntofu's Avatar
The dyno was on a dynojet. Thanks for all the suggestions and discussion guys really helping me out. I was going to turbo it, but then found out I'd have to change out my high lift cams, and probable put in lower compression pistons if I wanted anything over 10psi of boost on a gt35r. I guess im still going to debate on what I want to do. But like in star trek "WE GOT TO HAVE MORE POWER CAPTN!"
Old Jan 14, 2010 | 06:19 PM
00Red_SiR's Avatar
All Motor Mentor
Do you need that power 100% of the time or just when you want it? If it's just when you want it, there's always nitrous...
Old Jan 15, 2010 | 07:59 PM
boostntofu's Avatar
NOS + 11.1 = boom? or no?
I can actually get a pretty cheap EFI kit locally. Think a 50 shot would go to 10k rpm without detonation.
Old Jan 16, 2010 | 05:07 AM
D-Rob's Avatar
Nitrous + whatever compression isn't so much the issue.
It's the available knock resistance of the fuel you have to be concerned about.
- Derek
Old Jan 16, 2010 | 04:54 PM
00Red_SiR's Avatar
All Motor Mentor
What D-Rob said and the fact that you will not need to go to 10,000 Rpm to make power when running nitrous. I have 11.5:1 and run nitrous on a daily driver no problem with no boom and at 1500 RPM less than you want to run. Tuning and fuel is key.
realis9
Mar 5, 2007 10:22 PM
JDMSiGuy17
May 13, 2004 03:51 PM
djmatix
27
May 12, 2004 08:40 PM
b18junkie
15
Aug 21, 2003 05:07 AM
gsr98vtec
Dec 19, 2001 06:41 AM
