shift knob help
Old Sep 4, 2002 | 10:24 AM
Lost Type R's Avatar
Default shift **** help
i cant seem to fit the type r shift **** onto my skunk2 shifter... does it fit on there? or do i havta get a skunk2 shift **** now?
Old Sep 4, 2002 | 11:45 AM
Hunter's Avatar
Default Re: shift **** help (Lost Type R)
it should fit, make sure neither one are stripped or anything
Old Sep 4, 2002 | 11:58 AM
powerslide360's Avatar
I have a Skunk 2 shifter in my Civic with a JDM ITR/CTR shift **** - it is a bit tricky - you have to line it up perfectly like a lug nut on a stud. Clean the threads out with a wire brush and try lubing the threads with Never Seize or another lubricant. Make sure it is lined up properly.
If it doesn;t work, just bite the bullet and get the Skunk 2 shifter ****.
Old Sep 4, 2002 | 12:03 PM
R_yd's Avatar
Default Re: shift **** help (powerslide360)
it should fit....mine does.
Old Sep 4, 2002 | 12:09 PM
jonsteR's Avatar
My friend bought a skunk2 shifter and ****. They're a tight fit.
Old Sep 4, 2002 | 07:54 PM
90H22's Avatar
Default Re: shift **** help (jonsteR)
Forget that hard crap! Just put some weight on it and start screwing!
Warning: This may cause rethreading of components. Do not perform if you EVER planning on changing either item.
Old Sep 4, 2002 | 10:51 PM
JICsube's Avatar
Default Re: shift **** help (Two1Accord)
i had the problem with my skunk2 shifter and i had the skunk ****! wouldnt go on.. turned out the coating on the shifter was too thick so i had too get a tool too peel off the coating on the threads screwed in perfect now try that.
Red98GSR
Feb 4, 2011 05:41 PM
honda_coupe
Feb 24, 2007 07:17 PM
escape2me
Apr 2, 2005 03:57 PM
skygtr01
May 29, 2003 09:01 PM
dfoxengr
Dec 27, 2002 07:59 PM
