Should I buy a .48/.43 T3 Turbo for a H23a?
Old Jan 11, 2010 | 10:07 AM
cow1787's Avatar
Default Should I buy a .48/.43 T3 Turbo for a H23a?
I need this answered fairly quick. I can get a good deal on two .48/.43 T3 Turbos with an intercooler and was wonder if I should?
I don't know much (or anything) at all about turbos yet, always figured I'd do something eventually. If I get them the plan is to probably get another engine and build a turbo set up then drop it in once it's finished. Right now I've got an H23a.
What do you guys think?
Old Jan 11, 2010 | 11:36 AM
TheShodan's Avatar
Moderator
Default Re: Should I buy a .48/.43 T3 Turbo for a H23a?
Think FIRST what you want to do with the car, and if you have the resources and knowledge to put a "Saab" turbo into the car. Just because you get something for "free" doesn't mean it won't cost LESS to utilize a setup for it. It may be more trouble than its worth it.
You need to understand about turbochargers and their systems first before "jumping" onto that opportunity.
Old Jan 11, 2010 | 11:59 AM
thumper64's Avatar
I had a .48/.42 T3 from a LeBaron and it was tiny on the cold side. Get them if they're cheap, maybe you could make a twin turbo setup.
A T3/T4 works good on a B series, just an idea.
Old Jan 11, 2010 | 12:30 PM
Schister66's Avatar
Man U FTW
As TheShodan already asked, what are your plans for the car/setup? That would be the determining factor...just because you have a turbo, doesn't mean it is worthwhile to use it
95civhb
Feb 11, 2010 11:07 AM
Honda owner
Jan 22, 2006 08:55 AM
hondahatch741
May 30, 2005 12:36 PM
PFSeg
Jul 24, 2004 10:36 AM
.nate
Oct 3, 2001 01:11 PM
