how can i tell if i have a b16 head or itr??
Old Jan 11, 2010 | 08:37 AM
ej1252's Avatar
Default how can i tell if i have a b16 head or itr??
im sure this thread been brought up before but i couldnt find it in search.
im trying to see what my head is so i know what set up i have. i like to know if theres anyways to tell the b16 head jdm or usdm head from the itr head jdm or usdm??
it says 00 on the head too.
Old Jan 11, 2010 | 09:12 AM
91h22cb7lx's Avatar
Default Re: how can i tell if i have a b16 head or itr??
the intake side will be ported and polished slightly, and if it still has factory springs they will be dual valve springs, itr ctr and b16 heads are made from the same casting
Old Jan 11, 2010 | 09:28 AM
Top Ramen's Avatar
Right; if its a complete head, the easiest way to check is to just look at the valve springs. ITR will have an inner set.
Old Jan 11, 2010 | 10:03 AM
ej1252's Avatar
so your saying that the itr head has dual intake springs or both intake and exhaust?? and the others dont??
Old Jan 11, 2010 | 10:04 AM
ej1252's Avatar
both intake and exhaust? or just intake?
thanks
Old Jan 11, 2010 | 10:08 AM
Bseriescivic5's Avatar
both intake and exhaust springs are dual (IE an inner and outer spring) B16 only has dual intake spirngs if I remember correctly. you can also look at the cams to identify assuming they have not been swapped out previously.
Old Jan 11, 2010 | 10:17 AM
ej1252's Avatar
i see thanks
Old Jan 11, 2010 | 10:31 AM
98civicswapped's Avatar
he's right b16's only have dual valve springs on the intake side. Took a stock b16 head apart a lil while ago.
Old Jan 11, 2010 | 12:34 PM
Frankacura's Avatar
Get it double springs. light weight valves ans type R cams and there is no differance betwene the 2 head exept for the R spec one that is lightly ported at the bothom of the valves seat by honda...
Old Jan 11, 2010 | 01:38 PM
Hybrid96EK's Avatar
You can also look for the yellow or green paint on the dist leg side of the head on the top surface. All R heads have the paint unless someone has "cleaned" the paint off with a harsh cleaner.
Old Jan 11, 2010 | 04:56 PM
dont_loaf's Avatar
Well I had a couple of B16 heads and they had Pr3 stamped on the exhaust side and a friend of mine had a type R motor and his head was stamped P73
Old Jan 11, 2010 | 05:33 PM
Hybrid96EK's Avatar
Your friend is completely wrong. His HEAD is stamped PR-3. His INTAKE manifold was most likely where he saw the P73 stamp. The R heads are all slightly worked (intake side ports only) B16 castings. There were none with "P73" casting numbers.
Old Jan 12, 2010 | 07:49 AM
Correct, As stated earyler in this thread the ITR and B16a heads are identical castings. The valve springs would be the first place to look, then cams, then paint. It will be very hard to tell the porting, b/c you just dont know if someone has already ported a stockb16a head.
Old Jan 12, 2010 | 12:44 PM
Frankacura's Avatar
For the cams if you can show a pic with the end of the cams then the Grooves will tell you GSR b17a/ 94B18c / Si-R 1st/2nd or Integra JDM 96/USDM type R 2001/ CTR
Old Jan 12, 2010 | 12:51 PM
Frankacura's Avatar
Wit used parts always keep a eye bigger open. cause LOT of peaple will take from a blown Si-R the Intake inserts springs and put them on Si-R exhaust and THINK that is as type R springs... MISTAKE
Almost every things from a type R is bether exept retainers that is all same LOL
Old Jan 12, 2010 | 05:41 PM
ej1252's Avatar
just ripped open my motor, found out that it has itr cams by looking at the end of it.
still cant tell if its a b16 head or itr cause i cant see the valve springs.
it has green on the intake side springs, does that mean anything??
Old Jan 13, 2010 | 06:29 AM
If you pulled the valve cover, you should easilly be able to see the springs.
Old Jan 13, 2010 | 08:51 AM
ej1252's Avatar
still couldnt see it haha, im about to just take one retainer and go from there
Old Jan 13, 2010 | 11:54 AM
Frankacura's Avatar
Green on Intake IS defenetivly Si-R springs... Kind of tane on EX.
Old Jan 13, 2010 | 02:46 PM
ej1252's Avatar
yeaaa
Jacob Downes
Apr 26, 2018 07:45 PM
punkracer
Feb 22, 2010 08:15 PM
umair
Feb 23, 2009 07:09 PM
drudy
Jan 8, 2006 09:20 AM
JDMlyfestyle
Jan 14, 2004 03:59 PM
