turn signals not working on 00 si.. help please
Old Jan 11, 2010 | 07:47 AM
1cleanem1's Avatar
Default turn signals not working on 00 si.. help please
My hazards work but my turn signals dont. i have a 2000 si, I have searched but nothing on the topic is helping. any ideas? i need to get this fixed asap, thanks.
Old Jan 11, 2010 | 07:48 AM
ken9's Avatar
Default Re: turn signals not working on 00 si.. help please
Could be light bulbs issuses. See if you can take it out.
Old Jan 11, 2010 | 07:50 AM
brent_si's Avatar
If the hazards work then its not the bulbs. Check your fuses and wiring.
Old Jan 11, 2010 | 07:54 AM
1cleanem1's Avatar
thanks for the quick responses, the bulbs are fine... i checked the fuses and they seem good, but what wiring would I need to check? im a completely noob with wiring and ****. thanks
Old Jan 11, 2010 | 08:08 AM
1cleanem1's Avatar
bump, i need to fix this asap.. got a meeting to go to soon
Old Jan 11, 2010 | 08:14 AM
brent_si's Avatar
Check all the wiring around the bulbs. It may also be a good idea to take off the steering column cover to have a look.
Old Jan 11, 2010 | 08:15 AM
1cleanem1's Avatar
yea i have the cover off the steering column and everything, I tried searching again and ppl say to check the turn signal switch. do you know where that is and what it looks like?
Old Jan 11, 2010 | 10:19 AM
MonkeyMagic's Avatar
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
see the little green plug in the last pic? with the turn signal switched on you should have continuity between two wires. with it switched on the other way you should have continuity between the odd wire from before and the black striped wire.
if there is no continuity the switch isn't closing and is bad. if there is then the problem is somewhere else.
Azavala
Apr 8, 2016 02:14 PM
xyk
Dec 25, 2009 01:18 PM
kaluwa3
24
Mar 3, 2009 07:38 PM
eg8000rpm
Apr 27, 2005 12:37 PM
RTW DC2R
Dec 3, 2003 06:50 PM
