leaking antifreeze from bolt in blockloosing antifreeze threw back of block??
Old Jan 11, 2010 | 05:54 AM
missionaryrider's Avatar
Default leaking antifreeze from bolt in blockloosing antifreeze threw back of block??
hey guys theirs a screw right next to the oil filter, does anyone know what this is? why would antifreeze be leaking from here?
Old Jan 11, 2010 | 06:50 AM
97twodoor's Avatar
Default Re: leaking antifreeze from bolt in blockloosing antifreeze threw back of block??
Its the coolant drain plug for the block most likely. So coolant could be coming out of there if the bolt is loose or, the washer is old and not sealing correctly.
Old Jan 15, 2010 | 08:23 AM
k thanx man i will check it out
AndyD
Nov 2, 2009 08:02 AM
Tokonut
Mar 1, 2009 06:33 PM
HoNdAeX11
Jul 16, 2002 04:32 AM
Guitarman
May 27, 2002 11:44 AM
