Ek hatch ls swap turbo WHITE SMOKE!
Old Jan 10, 2010 | 08:59 PM
Lilsoldierbenny's Avatar
Default Ek hatch ls swap turbo WHITE SMOKE!
ok heres the deal, i blew my head gasket so i had to get it replaced. upon replacing it i resurfaced the head, now i turn it on to drive and it smokes crazyyy! it'll leave alot of smoke behind mee clouds of it which is embarrassing .
anyone got any ideas of what it could be?
my guess is the turbo oil seals are bad or something with coolant??
HELP ME!!!!!!!
Old Jan 11, 2010 | 07:30 AM
Default Re: Ek hatch ls swap turbo WHITE SMOKE!
ANYONE?
Old Jan 11, 2010 | 09:19 AM
jjspec's Avatar
How far have you driven it? Sometimes it takes several miles to get the coolant out of the exhaust!
Old Jan 12, 2010 | 04:53 PM
awhile.
my oil seals were bad on my turbo can that be it?
Old Jan 12, 2010 | 10:59 PM
Turbo_TONY's Avatar
oil has a blue-ish color to the smoke..white usually mean coolant is burning
Old Jan 13, 2010 | 07:33 AM
ohsnapzafingcu's Avatar
I serve phở for my babies
you probably cracked a sleeve, do a compression test.. and make sure all your spark plugs are out when you do it...
if your gasket was new, and a cylinder's compression is low you most likely cracked a sleeve
Old Jan 14, 2010 | 05:18 AM
sde780's Avatar
compression/leakdown test
did you torque the head properly?
oranginal
Apr 28, 2012 05:35 PM
bvillarreal
Jan 24, 2012 02:39 PM
93califerio
Nov 20, 2011 12:26 AM
avotegra
Dec 13, 2009 11:45 PM
oranginal
Jul 1, 2009 05:29 AM
