ACL Or OEM rod bearings
Old Jan 10, 2010 | 04:04 PM
accord2civic2prelude's Avatar
Default ACL Or OEM rod bearings
Just trying to figure out which rod bearings would be better! SOHC-V boosting 8psi. I've heard that the OEM rod bearings are pretty good with N/A or low boost! Anybody care to chime in...
Old Jan 10, 2010 | 04:07 PM
MonkeyMagic's Avatar
Default Re: ACL Or OEM rod bearings
**** i've even had good luck with clevite bearings.
Old Jan 10, 2010 | 04:26 PM
blackeg's Avatar
oem allows you to get all your tolerences much closer because of the color codes. i think acl's are just the middle "green" size.
Old Jan 10, 2010 | 04:34 PM
ok.how much of a difference are the rods from each series? Like can i use bearings from a h in a d or b in a h? Im not too sure of how much bigger the crank is between them.
Old Jan 10, 2010 | 04:40 PM
steveo135's Avatar
why would you put bearings from an H series in a B series? Don't fvck around with that stuff. Get exactly what size you need for exactly what motor you need.
Oem bearings are better as stated above because they come in different sizes for different clearances.
Old Jan 11, 2010 | 06:03 PM
im not i was just asking for my personal knowledge that's all.
Ok, had a small knock in the block this weekend so i pulled the oil pan and there were shavings in it. so i wiggled the rods and #3 was wiggly from side to side only. does anyone know which plastigauge color i am suppose to use? d15b7 block.
Jdm_Ej8_Sedan
Jan 29, 2014 05:34 AM
X E Ryder
Jul 18, 2013 08:24 AM
eg:R
Sep 14, 2006 09:36 AM
Speed Infliction
May 1, 2006 07:24 PM
totalimpact
Nov 11, 2003 06:39 PM
