Just bought ITR front and rear sway bar for only $90
A brand new rear ITR sway is about $70, so $90 for both is a good deal if you've got an LS/GS/SE and not a GS-R, because the ITR front sway is the same as the GS-R front sway.
Only $70? I thought they were more..hmm that still a decent deal then, since they are 24mm. They are huge compared to the stock ones.
USDM rear sway is 22 mm, GS-R rear sway is smaller.
LS/GS/SE front sway is smaller than GS-R/ITR front sway, which are the same.
Might as well install the front, as it will still tighten things up a bit if you've got an LS.
There are tons of threads on how to install w/o a asr subframe or anything. I'm pretty sure the 00-01 ITR were 24mm front and rear. The earlier ones were 22mm. I do plan on installing both as it would make an improvement with both. My car is originally a rs, so with these the handling should dramatically improve.
JDM ITR was 24mm.
USDM ITR was 22mm.
Integra model - Front / Rear diameter (mm)
86-89 All Models - 17.0 / 17.0
90-93 All Coupes - 23.0 / 14.7
90-93 All Sedans - 23.0 / 15.9
94-99 RS/LS/GS/SE Coupe - 22.1 / 12.9
94-99 RS/LS/GS/SE Sedan - 22.1 / 14.0
94-01 GS-R - 24.0 / 14.0
97-01 Type R - 24.0 / 22.0
00-01 LS/GS Coupe - 24.0 / 12.9
00-01 LS/GS Sedan - 24.0 / 14.0
the front one is pretty much pointless to put on.
heres what you need for the rear ITR installation
Parts needed for the install:
# 01. 52300-ST7-Z01 rear sway bar – Quantity: (1)
# 02. 52315-ST7-Z01 sway bar bushing – Quantity: (2)
# 03. 52308-SS0-000 bushing bracket – Quantity: (2)
# 04. 52316-ST7-Z00 end link bushing – Quantity: (2)
# 05. 52312-ST7-Z00 end link bushing collar – Quantity: (4) – can be reused from the stock sway bar but recommended to get new ones.
# 06. 90175-ST7-Z00 bolt (8x35) – Quantity: (2)
# 07. 94050-08080 flange nut (8mm) - Quantity: (2)
all info taken from team-integra.net
heres the ITR install link
http://www.team-integra.net/sections...?ArticleID=692
and heres the sway bar article
http://www.team-integra.net/sections...?ArticleID=295
Basically, the ITR was reinforced in the rear subframe compared to the other Integras (other places too, but that's another topic). Installing the larger ITR rear ARB without some form of support can cause the additional stress to tear the metal (or so they say, no personal experience).
All I know for sure, is that there is plenty of talk about damaged subframes, and I installed a Comptech brace with my 24mm ARB.
whats the cheapest brace around that I could buy for it, I didn't intend on needing a brace as al lthe DIY on isntalling a ITR sway bar doesn't usually include one.
The cheapest subframe reinforcement kit is the bsq kit. The next cheapest is the beaks kit, which is the one I went with 5 years ago. Then there is the asr which is significantly more expensive, but also allows you to run a tie bar if you want.
Not suspension, but the subframe that the suspension mounts to. This is actually worse than damaging the suspension, since welding is required to install a replacement.
oh, your referring to the beaks metal piece kit for like $20?? I was thinking pwards of $150...whew almost scared me
52300st7z01, 52308ss0000, 92, asr, bar, bracket, front, install, installing, integra, itr, kit, needed, rear, sway
