need some pics or diagrams
catch can....6 lines......four on the valve cover, 2 on the back of the block.
vacuum manifold......depends on your set up.
there is TONS of info on this site.
the vac block goes to all your sources that need vac such as bov w.g. fpr boost gauge. u get the main vac source by T into your brake booster vac line
thats cleared it up thanks guys
yeah loads of info on here been on here for a few weeks now only joined today tho.
im member of a few sites in the uk but im going to be building a b20 turbo engine at the end of the summer so came here as turbo hondas are more common in the us than they are is the UK,
thanks guys
thanks guys
tial wastegate un sure what turbo yet as not sure how much power i what to run, i also like the look of neukin manifolds iv heard some good stuff about them, apart from the time it takes to get one, you ever used one? are you running a turbo setup?
