Need help dose a dc2 teggy brake master cylinder fit on my 2000 dx civic???l
?? Need help just changed my front spindles from my 2k dx civic to dc2 ls ones and now I barely have any pressure on my brake pedal...I bleed all the brakes n still the same so I was thinking maybe its my brake master cylinder mayb its not pumping enough fulid. So I wanted to know if anybody know if a 98 teggy MC would fit on my dx civic do I have to change the booster??????or wat would I hav e to do to fit it on ???? Plz help me out I couldn't find shyt couldn't find shyt
When i did a rear disk conv. on my 00 Si, i had to use mc and booster from dc but gotta make sure its non-abs and bleed them starting RR-RL-FR-FL
Thanks bro guess ill start looking for a non ABS MC n booster cause bleedlik two days ago n it still pretty bad...but thanks for the help bro
?????? dose anybody know if i was just to get MC from a dc would that fit on to the stock power booster i got in my Dx
kk so i changed the the booster and mc know the pedal dosent reach all the way to the brake switch so the brake lights are always on....... has anybody ever run in to this problem
Make sure your brake pedal height is good(pic1)adjusted by push rod should be 6.16 in. also check free play can be adjusted by brake switch(pic2) 1-5 mm, for free play press pedal slightly with the car off, hopefully this help
thanks alot bro but i put the push rod all the way out n the brake pedal still doesn't reach could i bring out the brake switch?????
spaceman00
Jun 4, 2007 09:06 AM
