ANYONE DONE A 5 LUG SWAP ON EM1?HELP
Old Jan 9, 2010 | 06:14 PM
carbon_si's Avatar
Default ANYONE DONE A 5 LUG SWAP ON EM1?HELP
like the title says,anyone done a 5 lug swap on em1? im curious if im going to run into any problems or if its just going to go smooth.also im thinking of running ap1 s2ks for the rest of winter"4 fronts of course" and curious if they will fit good.
Old Jan 9, 2010 | 06:16 PM
DualCamEJ's Avatar
Default Re: ANYONE DONE A 5 LUG SWAP ON EM1?HELP
they should fit good with no problems
Old Jan 9, 2010 | 06:44 PM
madm@nkey's Avatar
Done it. It's time consuming but fairly easy. Are you getting the 5 lug off a US spec ITR or Civic Type R?
If so there should be no problem with the EM1 axles fitting the 5 lug hub.
Your EM1 and the US spec ITR and Civic Type R all run the smaller 32mm splined axles. The JDM ITR uses a 36mm axle.
Old Jan 9, 2010 | 10:03 PM
carbon_si's Avatar
jdm 36mm but it coming with axles
jxnguyen
Apr 21, 2015 05:57 PM
Ek9_Cuhzz
Northwest (Sales)
Jul 27, 2010 09:08 PM
Vl4d
May 22, 2007 11:19 AM
RhdRicheeee
Nov 21, 2005 04:06 PM
00hatch98r
Mar 31, 2003 03:58 PM
