B18C TDC Issue
Old Jan 9, 2010 | 05:34 PM
f22a's Avatar
Default B18C TDC Issue
I have an issue with my JDM B18C. I'm in the process of replacing the timing belt / water pump / front crankshaft seal, and I noticed when I went to remove the crank pulley bolt that the white timing mark on the crank pulley is about an inch to the right of the lower timing belt cover TDC mark. The engine has been running just fine in it's current form.
My question is, when I put the new belt on, should I position the crank pulley in the same position as it's in now, align the crank pulley TDC mark with the lower timing belt cover TDC mark, or set TDC with the number one piston? What could be the cause behind the timing marks being that far off?
Sean
Old Jan 9, 2010 | 05:44 PM
DJYoshaBYD's Avatar
Default Re: B18C TDC Issue
here ya go **thumbsup**
http://www.c-speedracing.com/howto/timingbelt/tbelt.php
Old Jan 9, 2010 | 05:51 PM
f22a's Avatar
Thanks for the heads up. I guess it's possible that the last time the belt was replaced, they simply didn't line the crank pulley up right on?
Old Jan 9, 2010 | 06:11 PM
f22a's Avatar
Also, while I'm at it, what is the process for removing the lower timing belt sprocket to replace the front crank seal?
Sean
DavidCRV
Aug 26, 2013 03:12 PM
suje
14
Feb 22, 2012 04:19 PM
Powered by VTEC
Jan 29, 2008 05:58 PM
94dxt
Oct 27, 2004 12:36 PM
Jonathan_ED3
Apr 12, 2003 02:55 PM
