99 EK
whats the difference gsr or a gsr with b16 head? you'll have same torque and hp. I would go gsr with b16 head and ls
or screw the hassle and just get the motor freshened up and give it 8-10lbs of boost. DONT FORGET A PROPER TUNE
or you can sleeve the block, put some low comp. pistons, a good head job and you can give that thing a good 20lbs boost
btw there is so much info on HT about this so do some research
ok sounds good. i bought the whole shortblock gsr for 150 so i imagine i could use some better pistons never been a fan or srp either. Yes the block is already got sleeves in it and lower comp pistons so we will see what the machine shop says thanks all for the good advice
really? what kind question is this? what are you even asking?
my real advice, do some homework and research what's already out there.. you'll find your answer to whatever you need or you'll blow it up. one or the other.
RustyRex
Oct 21, 2003 12:45 PM
