how many teeth on 4.785 jdm itr final drive gears?
If you don't mind counting go to godspeed.hack.net, in the Honda section, there is a photo of the final gear where you can see all the teeth.
Sorry I'm too lazy to count myself
when using the first drive gear, what is gear ratio??
SAME.
SAME.
Actually the total gear ratio (first gear and final drive) will be 1.088 x higher (4.785/4.4)
In the context of that question, I took it to mean "what is the difference in ratio from the jdm 1st gear to usdm 1st gear?" They are the SAME ratio.
The ACCELERATION multiplier is correct as you described above.
My real question is, say the 4.40 drive 1st gear ratio is 2.929...
what is the 4.785 drive 1st gear drive ratio??
And can you use different first gear ratios with the 4.785 FD kit...
SAME. 2.929
Yes, you can use whatever 2-5 gears you want (quaife, kaaz, ATS included...)
dsisive407
Mar 6, 2006 07:15 AM
