Help:: My car is bogging/struggling on start up??
Old Jan 9, 2010 | 07:29 AM
slikz714's Avatar
Default Help:: My car is bogging/struggling on start up??
Old Jan 9, 2010 | 09:12 AM
Jimster480's Avatar
Default Re: Help:: My car is bogging/struggling on start up??
does it burn coolant normally? because it sounds like you could possibly have a small leak in your HG and coolant/water is seeping into the cylinders while the motor is off, makiing it difficult to start. That is what happened to me last year, when i had a finicky headgasket.
Old Jan 11, 2010 | 03:51 AM
slikz714's Avatar
Old Jan 11, 2010 | 05:08 AM
Jimster480's Avatar
Originally Posted by slikz714
i think its burning coolant properly?? im not sure though, i haven't payed attention to it yet which i will now.
when i do try and start it up though for the first time of the day it usually bogs out on the first try and smoke would come out of my intake?? what does that mean??! lol ;\
could be a oil or water buildup around the valves, or just coolant in the cylinders.
Old Jan 11, 2010 | 05:23 AM
johnzy00's Avatar
any chance when you hit that rock it jumped a tooth or so on your timing?
Old Jan 11, 2010 | 06:33 AM
itsnotfast's Avatar
Definitely sounds like coolant buildup in the cylinders. The problem is likely unrelated to the oil pan incident, unless you overheated the **** out of your engine in which case you probably would have severe bearing problems as well. You probably have a pin hole leak in the head gasket.
Old Jan 11, 2010 | 09:12 AM
slikz714's Avatar
Old Jan 11, 2010 | 09:14 AM
slikz714's Avatar
Old Jan 11, 2010 | 09:15 AM
slikz714's Avatar
a
Old Jan 11, 2010 | 09:28 AM
Jimster480's Avatar
if it is coolant.. how'd coolant leak to the cylinders in the first place??
from a tiny leak in the headgasket which allows the coolant to slowly seep in as the motor is off. But when it is on (if its leaking at all when its on) its too little for you to notice. Its just like with my turbo seals atm, when i turn the car off for a while the oil from the turbo slowly seeps into the back housing. SO when i turn the car on and the exhaust starts to heat up, it smokes until the oil is blown out (either by me accelerating, or just slowly burning off). But once that happens the exhaust doesnt smoke.
Old Jan 11, 2010 | 09:29 AM
itsnotfast's Avatar
how can you tell if it did jump a tooth or not?? i tried to look at my timing belt b4 but couldnt tell the difference lol.. the belt is still on pretty tight like usual though
Line up the lower marks on the timing cover and the crank pulley and take you valve cover off and make sure all the marks are lining up to spec.
It has to be a pin hole leak in the head gasket. A compression test may not give accurate readings as water/coolant can not be compressed and may read higher if its only a pin hole leak. Take the rad cap off and see if you are getting bubbling as the car is running.
deanandon
Honda Civic (2001 - 2005)
Jan 3, 2013 08:16 PM
cleanazcoupe
Nov 27, 2010 06:51 AM
tek_civic
Feb 16, 2006 06:43 PM
94gsr18kid
Dec 29, 2004 08:12 AM
SPORT INJECTION
Aug 25, 2003 12:15 PM
