what torx size are these screws
Old Jan 8, 2010 | 09:27 PM
cjhmarine's Avatar
Default what torx size are these screws
have a 91 civic si and need to replace brake line, need to take off door sill trim peices that have 2 torx screws what size are they so i can buy the right torx?
Old Jan 8, 2010 | 09:48 PM
Eighty-Nyne's Avatar
Default Re: what torx size are these screws
Why buy a single one? Save money on a set so you don't have to ask this question again.
Old Jan 8, 2010 | 09:54 PM
whitetoy's Avatar
I had a tough time getting those out. Not sure what the exact size is, but I found that a T40 seemed to fit pretty good. Soak em in PB blaster real good first, and be careful not to strip them.
Old Jan 9, 2010 | 08:52 AM
JDMefHATCH7's Avatar
ohh you mean the ones that are covered by 2 lil caps by the bottom of the door..
i had to remove those last week to semi remove my carpet(fold) to work on ecu properly and..
no i do not remember the exact size
but your best bet is to get one of these
http://www.sinclairintl.com/images/large/TL09-l.jpg
cheap and all...but it does the job for any torx hardware youll find on Efs
if not buy a better set
btw what happened to your break line? are you going to change the entire thing?
i was thinking about that the other day what if the line was to get fxcked up at some point of the chasis...
post pics
Old Jan 9, 2010 | 01:31 PM
durfeec's Avatar
t40
Old Jan 9, 2010 | 01:48 PM
88Hatchy's Avatar
You don't have to worry about this if you buy quality tools.
Old Jan 9, 2010 | 08:29 PM
cjhmarine's Avatar
the first picture is what i took off second is where it was leaking third is overview fourth is rusted line that blew, other is after i replaced line
Old Jan 9, 2010 | 08:53 PM
hatcht9x's Avatar
man I had to take those off last week.. they were in there pretty good.. when I got to the passenger side the 'nut' welded under the tub broke free so I had to sawjaw the bolt off =/
as mentioned.. soak in pb blaster before hand
Old Jan 9, 2010 | 09:27 PM
cjhmarine's Avatar
question, i bled the brakes and since its original the bleeder screw broke/snapped leaving it closed and half still in, how can i replace/repair do i have to tap it and put in spring to create new threads?
Old Jan 9, 2010 | 09:30 PM
hatcht9x's Avatar
you can try to use a reverse drill bit to spin it out.. or use one of those as seeen on tv gator grab bits.. just be careful
Dekorum
11
Sep 1, 2013 06:45 AM
JSiRTO
May 9, 2007 08:04 AM
GS-Rcivic
Jul 31, 2003 09:09 AM
xpurespeedx
Sep 12, 2002 09:55 AM
