EF wont start if weather is to cold!
Old Jan 8, 2010 | 09:11 PM
HongoRLS's Avatar
Default EF wont start if weather is to cold!
THANKS HT. PRBLEM SOLVED! I CHAGED THE IGNITION SWITCH N THAT DID IT, SOLDER WER CRACKED N WIRES WER NOT MAKING GOOD CONTACT.
wuz good HT, need sum help plz. So this is what i do to start the car, I take a hair dryer and aim it at the ignition wires for 30sec (cold days 50-40 dagrees) behind the steering wheel by the wiper/turn/haz switch, turns on fine after of course untill it get cold inside the car again!
Things checked/changed
starter
batteries (yellow/red-tops)
fuel relays
ECU's
alternators
I dnt knw what else 2 chx plz leave comments.
Old Jan 8, 2010 | 09:57 PM
whitetoy's Avatar
Default Re: EF wont start if weather is to cold!
starter
fuel relays
ECU's
alternators
If heating up the plug wires does the trick, you might try replacing those.
Old Jan 8, 2010 | 11:25 PM
rice_classic's Avatar
So if the car won't start until you heat up the INTERIOR then the problem must therefore be in the interior. If I was a betting man I'd say it's either your ignition switch your main relay.
Old Jan 9, 2010 | 12:36 AM
HongoRLS's Avatar
I think I'll try the ignition nxt, if the weather gets better in N.Y.(L.I.-EXT.21) THANKS.
KEEP IT GOIN HT MEMBERS.
Old Jan 9, 2010 | 12:44 AM
The ignition switch is not common and not that "easy". The Main Relay is very common and quite easy. Try the main relay first. Once you take it out you can open it up and see if the soldered points have separated. I've found this on 1 crx and 1 accord. I just resoldered the points back together and voila... car started like a dream.
Old Jan 9, 2010 | 05:06 PM
Targa250R's Avatar
be professional
starter
fuel relays
ECU's
alternators
You need to give more specific details. What exactly happens when you turn the key? Does the starter crank the engine, but the engine just won't start? Is the starter not cranking, and instead you just get one click? A series of rapid clicks? No clicking at all?
Old Jan 10, 2010 | 10:08 AM
ICE888's Avatar
Main relay typically does NOT work when it is HOT....because the solder points are separated...
Old Jan 10, 2010 | 11:02 AM
D16SiHatch's Avatar
what he said ^. isolate whether the ign switch is the problem (won't crank), or if its the main relay (cranks but won't start and run on its own)
88 EF Hatch
Jun 27, 2009 06:52 PM
tampabitches
Aug 14, 2006 02:56 PM
crvtechjin
63
Jul 12, 2005 03:11 PM
rkonfire
Apr 21, 2004 07:16 PM
