Having issues starting car...
Old Jan 8, 2010 | 06:41 PM
EGHondalover88's Avatar
Default Having issues starting car...
So here is whats wrong, Car about a few months ago just had problems starting one morning, finally got it to start and drove it to work. After work i went to start it and it wouldnt start, fiddled with connection issues, tapped on starter, finally just pushed started it. Few days later it was completely dead. Wouldnt even jump or push start.
I have checked battery connection its fine, Battery is brand new.
Starter works fine as well, found something unplugged at first but its fine now.
Besides the other issues the car has im unsure of what all could cause it to just not run. I mean it wont even jump start anymore it tries and tries but it wont.
Old Jan 8, 2010 | 07:34 PM
matt j's Avatar
Default Re: Having issues starting car...
check the alternator, and pull the starter as well and take them in and have them tested at a parts store, sounds like the alternator is either undercharging or overcharging your battery, as far as the starter, its simple to pull and might as well just make sure.
alright will do for now and ill post the news once i find out.
Old Jan 8, 2010 | 07:36 PM
matt j's Avatar
awesome man, if you need any help just pm me.
Old Jan 8, 2010 | 07:37 PM
should i take battery in as well?
Old Jan 8, 2010 | 07:45 PM
also i assume if they are bad and i replace ill need to jump start car again if it was messing up the battery?
Old Jan 9, 2010 | 05:35 AM
matt j's Avatar
might as well take the battery in as well, since it is new it should still have a warranty if its bad, if its not it will have a full charge on it after testing, my guess is the alternator is toasted and may have taken the battery out as well.
Old Jan 9, 2010 | 07:14 AM
alright cool im gonna work on it tomorrow. ill keep you updated.
Old Jan 9, 2010 | 09:14 AM
matt j's Avatar
sounds good man.
Old Jan 10, 2010 | 11:50 AM
so went to advanced auto and they said both were totally dead and bad. battery is fine. ill be installing them this weekend and hope it keeps it running.
Old Jan 10, 2010 | 01:43 PM
matt j's Avatar
well once you get them put in let us know how it goes, at least you got to the route of the problem fairly quickly
Old Jan 10, 2010 | 02:08 PM
yea they said the started wouldnt even engage it was ****ed and the alternator once it was plugged in the charge went straight to zero. it will be about 260 to replace both. ill be putting them in on saturday.
another issue i gotta fix is my coolant leak into my passenger floorboard, heater core isnt installed and i think they didnt reroute it correctly.
Old Jan 10, 2010 | 02:50 PM
MonkeyMagic's Avatar
get the alternator and starter tested somewhere else.. the chance of them both going dead at the same time is one in eleventy billion.
Old Jan 10, 2010 | 03:02 PM
i watched them test it. twice.
Old Jan 10, 2010 | 03:04 PM
good for you
Old Jan 10, 2010 | 03:06 PM
lol. feel good about being a dick on here? * high five*
Old Jan 10, 2010 | 03:11 PM
SNOAH's Avatar
screw it might as well replace them both cause you never know the other could just die then after you replace the one if another place says its ok
Old Jan 10, 2010 | 03:14 PM
TylerB's Avatar
He wasn't being a dick you are just sensitive. He was only trying to help. Take it to another parts store and have it tested.
I work at a parts store and see this all the time. People will come in and say they just had it tested and someone told them it was a bad and then when I test it, it tests good. Spend the extra 10 minutes and have it tested elsewhere, it may save you some money.
Have you tried hooking it up to a battery to see if it engages?
Old Jan 10, 2010 | 03:16 PM
only 260 to replace both so yea its not gonna be a bad idea.
Old Jan 11, 2010 | 05:27 AM
matt j's Avatar
i would just take the heater core thing out of the loop and loop the heater hose back into itself
Old Jan 11, 2010 | 07:00 AM
its whats the guy i bought it from tried doing, but it leaks like a freaken hose into my floorboard. i found where it leaks and its not a slow drip. so gotta figure out why its doing it.
Old Jan 13, 2010 | 12:45 PM
matt j's Avatar
if i had my camera i would take pics of how mine is routed, i completely removed my heater core so i just looped the hose off the thermostat housing back in to the back of the block where the other hose would normally be
Old Jan 13, 2010 | 10:15 PM
found a shop that can fix it all for very cheap. cost of maybe hours work and new hoses.
Old Jan 15, 2010 | 08:18 PM
matt j's Avatar
it actually is a pretty easy fix, are you still running a heater?
Old Jan 15, 2010 | 08:53 PM
no the heater core is not installed. i need to take a look at the hoses see whats going on...
