Stock fuel PSI in a b18b?
what does the stock regular in a b18b run for fuel psi?? Mines reading 35 at idle and 40 on the gas. My car is running very rich and skipping. I have no cat in, and possibly foulded a o2 sensor with the cel i got. thanx.
Your pressure seems normal so maybe you have a sticking injector. Try to listen to them at idle and see if they are clicking. It helps to use a stethescope or a long screwdriver. It could also be an ignition problem and the fuel isn't being burnt.
