b20 type r turbo problems
Old Jan 8, 2010 | 11:26 AM
boosted20psi's Avatar
Icon6 b20 type r turbo problems
I have a 1997 civic ex with a b20 block and b18 type r head its fully built and turboed pushing 20psi. I have been having a problem when i get on my car kinda hard. It builds boost fine but when vtec is supposed to kick in it spits and sputters and i loose all my power. I have check all connections to the ecu and the vtec sylenoid. If anyone has any clue to what could be going on please give me some tips thanks.
Ryan
Old Jan 8, 2010 | 12:20 PM
vwslayer's Avatar
Default Re: b20 type r turbo problems
sounds like it wasnt tuned for vtec..........
Old Jan 8, 2010 | 12:34 PM
Sliced Beard's Avatar
When was the last time you replaced your fuel filter? What did you use for tuning? Who tuned it?
Old Jan 8, 2010 | 12:40 PM
its tuned for vtec its drag and drift tuned it ran perfect i havnt changed the fuel filter since i did the work to the car wich was about a year and a half ago
Old Jan 8, 2010 | 02:13 PM
Gunmetal_B20_Hatch's Avatar
probably needs new muffler bearings.
Old Jan 8, 2010 | 02:31 PM
93egSLEEPER's Avatar
do you have any CELs?
Old Jan 8, 2010 | 02:37 PM
Linked's Avatar
LMAO
OP anyway to find A/F ratio during vtec (datalogging?)
Old Jan 8, 2010 | 03:52 PM
no codes are bein thrown
Old Jan 8, 2010 | 05:40 PM
Evo1003's Avatar
the tune is not correct check ur mapping on the high cam side not the low cam
Old Jan 8, 2010 | 05:58 PM
what exactly do you mean the mapping on the high cam
Old Jan 8, 2010 | 06:01 PM
jdmwannabee's Avatar
Ryan
i think that's your problem...
your tune that is...
Old Jan 8, 2010 | 06:04 PM
what kind of tune should i get
Old Jan 8, 2010 | 06:57 PM
Evo1003's Avatar
ok idk if u tune ur car or u take it to someone but i use hondata pro and chrome, there are tables for low cam and high cam, which u can add more fuel or remove fuel at certain rpm its best be done on a dyno and toggle real time so u can see where you problem occurs because right when it starts to sputter u can see the area on the table where the problem is occurring. Reply back thanks
boosted20psi
Jan 12, 2010 12:32 AM
topherchris
Nov 6, 2008 03:49 AM
SUCIO D_BOY
Apr 17, 2008 01:27 PM
ballerboi23
Jun 23, 2007 06:54 PM
turbo_smallblockchevy
Jun 23, 2005 09:47 PM
