B18 vs B20
Old Jan 8, 2010 | 10:30 AM
sekoo_88's Avatar
Default B18 vs B20
What would be every thing needed to swap in a B20 engine into a 1992 gs teg. I knw tht harness and probabley ecu's need to be changed but is thr anything els such as axels or cud the stock ecu still be used?
Old Jan 8, 2010 | 10:32 AM
del sol noob's Avatar
Default Re: B18 vs B20
you can use everything of your ls on the b20 same wiring harness and tranny and axles and the ecu the b20 is the same thing as a b18
Old Jan 8, 2010 | 10:42 AM
sekoo_88's Avatar
thanks man i new tht the B18A1 and the B20 wer the same except tht the B20 was a little bigger and had more torque but i though ti had to chang wireing and other stuff.
Old Jan 8, 2010 | 10:48 AM
sekoo_88's Avatar
Another question the B20a and B20b wud still just drop right in or wud i just go with the B20b?
Old Jan 8, 2010 | 12:18 PM
DJYoshaBYD's Avatar
b series will bolt up to a b series.. lol...
any of the b-series will drop right in.. if you are going from b18 to b20, your answer is yes to pretty much everything.. its just a b18 with a bigger bore
Old Jan 8, 2010 | 12:20 PM
DJYoshaBYD's Avatar
oh yeah.. i forgot.. except the b20a5.. that is NOT a REAL B series.. it came from an 88-91 prelude 2.0 si
its a wannaB20.. HAHAHA.. its more like a dual cam f series than a b series.. b20b or b20z only.. if i remember correctly
Old Jan 8, 2010 | 12:30 PM
sekoo_88's Avatar
Lol thanx yosha so th ecu and wireing and everything shd work like u guys are saying sweet. The reason tht im dropin in the B20 is cus my B18A1 bent a valve so the head is bad and a friend of mine is giving me his full B20 for $100 so i just felt like droping in a newer engine with less miles and a little more torq
Old Jan 8, 2010 | 12:55 PM
DJYoshaBYD's Avatar
DO IT DO IT DO IT!!!! what a great ****ing deal..
you are all good.. ecu and all.. just bolt in, and enjoy a more torquey motor
Old Jan 8, 2010 | 04:51 PM
josh-roy's Avatar
b18a1 is obd0 and a b20 is obd2....
Old Jan 9, 2010 | 09:21 AM
sekoo_88's Avatar
See i knw tht so i thought i had to get a differnt ecu one thts obd1 harness
Old Jan 9, 2010 | 10:55 AM
DJYoshaBYD's Avatar
no.. you dont... you use your b18 dizzy, intake manifold, and sensors, and put them on your b20...
Old Jan 9, 2010 | 11:55 AM
DumaDA's Avatar
everything will bolt up correctly without modifying anything
Old Jan 9, 2010 | 06:10 PM
Rediness_code's Avatar
x2
Old Jan 10, 2010 | 11:35 AM
sekoo_88's Avatar
Thnx guys thts legit i knw a bit about hondas u knw the normal D series and some gsr stuff but i like B series so much more, but i got so much to learn still on the tunning and swaping aspect of hondas.
Old Jan 10, 2010 | 01:30 PM
cybreedjay's Avatar
he has a 92 b18a so its obd 1
Old Jan 12, 2010 | 05:13 PM
DC2fab's Avatar
b20b more of a torquey motor while a b18 is more of a high rev top end motor
Old Feb 25, 2014 | 12:01 PM
ditch diver's Avatar
So just to be 100% clear b18 harnes sensors and manifolds all change over to the b20 during the swap. Or do I have to use the b20 harness.
Old Feb 25, 2014 | 12:25 PM
aftermath1312's Avatar
This question was answer already but ill help you out.
Get the b20b or b20z. Your only going to use the block and head. Transfer your intake and exhaust manifold from your b18a to the b20. Use every single sensor and distributer from the b18.
You mention your getting a b20a. That wil NOT work on your car so don't buy it at all.
Old Feb 25, 2014 | 12:57 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
B20A's are from preludes. You can't use that in a civic/integra
Old Feb 26, 2014 | 01:23 PM
blackeg's Avatar
you can use the sensors from the b20, the plugs are all the same iirc. you may have to run the iacv from the integra. you will need to swap the drivers side mount to the block from the b20 to the one from the teg. the rest is great advice, both manifolds, the throttle body, distributor etc are all from the teg. you may want to swap over to the teg dipstick too.
you can run the integra ecu, but may want to raise the fuel pressure a bit as the b20 can run a bit lean at cold start and wide open just straight up off the ls ecu.
Nameless RB26
14
Jul 29, 2009 06:10 PM
CIVIC-2K
Mar 23, 2008 12:00 AM
Ls91sI
Apr 22, 2005 03:18 PM
91preyludesi
Jul 25, 2004 11:29 PM
mi2lo4u
Nov 15, 2002 07:42 AM
