ECT water temp sensor... need some help
Old Jan 8, 2010 | 10:21 AM
EFLS89's Avatar
Icon6 ECT water temp sensor... need some help
I have a 1990 civic si, with a OBD-0 LS motor. i bought the car with a wire tuck already and it always had a c.e.l. so i run the code and get a code 6. water temp sensor. this must be whats causing the very long starts. the problem is this.. I CANT FIND ANY WIRES FOR THE SENSOR OR TO WHERE ITS LOCATED. theres one sensor on the side of the head, under the distributor. and theres another one behind the block. im pretty sure its the one on the head. CAN ANYONE PLEASE show me a picture of there obd0 ls and what color wires the sensor has or a wire diagram that can show me where to find the wire. i would greatly apreciate it.
Old Jan 8, 2010 | 10:48 AM
D16SiHatch's Avatar
Default Re: ECT water temp sensor... need some help
the 2 prong sensor on the side of the head is the temp sensor for the ecu. the wires for it should be very near that area. the 1 prong connector next to it provides temp readings to the gauge cluster. the 2 prong on the back of the block is for the coolant fan switch. if it's not plugged in, the coolant fan will never come on.
Old Jan 8, 2010 | 11:10 AM
EFLS89's Avatar
ok i see, alright. so heres what i have done so far, remembering that the car has a wire tuck, there was one wire that was snipped with no connecter. that turned out to be the temp reading sensor, i took the sensor from a singlecam i had laying around and that was fixed. as for the wires for the ECT sensor (code6) there isnt any around that area, there is 2 wire behind the black that apear to be cut. i cant remember the colors off the top of my head but i know they shouldnt be cut. as for the fan, its direct connected to the ciggarette lighter, so i dont really have a problem with that. so now thanks to you i know its not the sensor behind the block. but i still need the info on the color of the 2 wires for this sensor. thanks
Old Jan 8, 2010 | 11:34 AM
4drEF's Avatar
Keyboard Humorist
Direct to cig? lol! why?
To each his own, but I prefer when things are hooked up properly.
If you don't care to fix this then don't worry about the 2 wires on the back of the block being cut.
concentrate on the two wire sensor on the head near the water neck for the ECT code.
Old Jan 8, 2010 | 01:44 PM
HondaPartsHero's Avatar
Technical Hero
the red/white wire should be C6 (+) and the green/blue wire should just be a ground
Old Jan 8, 2010 | 07:00 PM
JDMefHATCH7's Avatar
lmao femail
anybody got a picture of what the 2 sensors look like(to ECU and to dash)
and the one tht goes to the ecu is red and green if im not mistaken how about the 1 pin sensor what colors the cable?
im talking obd0 ZC idk if colors change when you go B series(obd1/2)
Old Jan 9, 2010 | 05:32 AM
Technical Hero
yeah I copied that link from an Australian website, ha
heres an OBD1 GSR the TW sensor is the water temp sensor to the ECU. The coolant temp sensor goes to your gauge.
check this thread for the OBD1/2 and OBD0 fan switch differences in wiring and placement with pictures
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/cooling-fan-isnt-coming-2606275/
Old Jan 9, 2010 | 08:24 AM
EFLS89's Avatar
lol i dont know, but thats the way i got the car bro. and im gonna look for that red and white wire in a few minutes. it sucks because i have to do this while its like 10 degrees outside. but hey,.. isnt that why we love our hondas..
Old Jan 9, 2010 | 03:28 PM
what plugs onto the coolant temperature switch tho?
Old Jan 11, 2010 | 03:12 PM
EFLS89's Avatar
its like a single wire outlet, you just stick it in. i believe the wire is green/yellow.
Old Jan 11, 2010 | 07:08 PM
anybody got pics?
going once...
going twice...
Old Jan 12, 2010 | 12:40 PM
EFLS89's Avatar
theres a pic that hondpartshero posted. look at the sensor. its like a little metal stick(in simplest terms) the plug for it would be somewhat the size of a straw..
ex) =] (its not a smiley face). the equal sign can represent the sensor itself, sticking out, and the other symbol would be the part you simply plug in. i dont know if i made any sense lol. but i dont have a camera to take pics. are you missing it or something?
Old Jan 12, 2010 | 12:54 PM
I think I might know what you're talking about
a little plastic straw looking joints with a metal crimpon connector inside them somewhat like the tranny reverse cables?
yeah I think I am missing it and I need to know asap as I'm finishing my finishing touches on my harness for my ZC so if anyone got a pic of the connector that plugs onto this sensor please post a pic...
jemo1
Jun 5, 2013 05:55 PM
93del
Dec 19, 2010 09:49 AM
foress_89
Jan 15, 2008 03:58 PM
teamvirus
11
Sep 1, 2006 03:05 PM
folta2169
Jun 8, 2005 11:30 PM
