FS: t3/t4 .57 trim turbo with fresh garrett rebuild from blaastperformance
Old Jan 7, 2010 | 08:57 PM
WGFletch4WS's Avatar
Default FS: t3/t4 .57 trim turbo with fresh garrett rebuild from blaastperformance
www.blaastperformance.com
sent this turbo off to blaast performance and had the full garrett rebuild done
never used the turbo in my project i never finished and now i have no need for it
325$shipped and paypald
Here is whats listed on there website for the package I ordered:
here is whats listed on there website:
Chinese Replica T3, T4 and T3/T4 turbos.
for all OBX, XSP, ZY, and other "noname" chinese-made turbocharger knock offs.
COMPLETE REMANUFACTURING to GARRETT specifications and with genuine internals.
Transforms your 129$ Ebay turbo into a Turbo of equal performance and reliability, and warrantied for 6 months just the same as a real GARRETT
- Remanufacturing to new of your housings and compressor wheel. The same compressor wheel is reused, so it needs to be in reusable shape. Otherwise, we can replace it by a Garrett compressor impeller for 60-80$ depending on model.
- Complete inspection as per GARRETT requirements
- All new GARRETT bearings and seals.
- genuine GARRETT replacement thrust system
- Porting of the turbine and compressor housing scrolls that are typically very rough.
- Balancing of the rotating assembly
- Pressure testing
- Re-assembly to GARRETT specs
- 6 months warranty coverage on remanufacturing workmanship and internals. Excludes impellers and shipping.
Our remanufacturing process includes the degreasing, gritblasting and polishing of all housings, brackets and impellers, including the machining flat of all flanges and the welding of turbine cracks when possible. Drilling & tapping of ONE broken stud or bolt is included. (each aditional is 10$ extra).
In case of excessive wear, specialized machining might be required in the center catridge, backplate or turbine shaft in order to install Under/over-sized bearings and seals as necessary to comply with original tolerancing requirements, which is an extra charge.
Old Jan 8, 2010 | 09:50 AM
Default Re: FS: t3/t4 .57 trim turbo with fresh garrett rebuild from blaastperformance
ttt
Old Jan 8, 2010 | 02:24 PM
bumppp
Old Jan 8, 2010 | 04:49 PM
SuicideSlide's Avatar
Do you have reciepts of the work performed?
Old Jan 10, 2010 | 03:29 PM
i have emails im prety sure ive bought and sold alot on here its rebuilt i have many people htat will vouche for it
Old Jan 20, 2010 | 08:17 PM
josh_schul's Avatar
pics are dead... and im interested. if i can get some pics that would be great
Old Jan 24, 2010 | 11:23 AM
turbojdmhatch's Avatar
still have?
Old Jan 25, 2010 | 08:18 AM
layzboifresh23's Avatar
pics?
StevieR
Feb 15, 2011 08:15 PM
SpoolnByYou
Jan 29, 2006 06:41 AM
booscivic
Dec 15, 2003 07:14 PM
