function 7 control arms
i have a 2000 civic EX with function 7 control arms.
I have a CTR 22 mm rear sway bar on the way
i have D2 coilovers with the standard spring rates(i believe this is 7k Front/5k rear, or either 9kfront/ 7k rear)
the LCA's come with 3 different mounting spots for endlinks. i guess they control how stiff or soft the sway bar is.....
i'm not sure as to which hole i should put the endlink through though. this is my first time adding a rear sway bar to any car.
I would contact Function 7 and ask them which hole is closest to the stock position and set it there. Or go with the middle. I think that is what they recommend anyway. You might want to check with Function 7 since I'm not positive about that.
bebeon_ek
67
Jul 7, 2005 09:53 PM
