Please help!! 2 problems
Ok so i ordered my chipped p28 ecu last week and it came last night. I put it in and a had a cel. This is on my 93 civic hatch with a b16a. I found that one wire had come loose, so i figured i would fix it this morning. So this morning I go out and then I dont know where the wire goes because they are not factory wires. the kid i bought the car from had them put in when his vtec controller got stolen. But i do get a code21. Now the next problem is a major one. The map sensor wire on connector d was taped together and it came apart. So i souldered it back together and now when i start the car it basically spits fuel out of the car. I need help ASAP!!! Even if your local to allentown we could meet up if you could help! Anyone please. The car barely runs now and and is dumping so much fuel!
Yes i know to check those two places. Im more concerned about the map sensor white wire. I soldered it together and it still runs like ****. It is better than before. It atleast idles now, before it wouldnt even do that.
The code 21 is the vtec selenoid since you got a swap try to rewire the selenoid from the ecu again, this is how you do it. VTEC Solenoid Yellow/Green wire to A4
VTEC Oil Pressure Sensor Blue wire to D6
VTEC Ground Black chassis ground
this problem has nothing to do with your map sensor.
here just in case you need it this is the pinout.
Here is a p30 pinout, you can use this as a reference because this and a p28 are basically the same and you can use it to figure what plugs a b or d and which way to look at it
A1 BRN INJ1 INJ1
A2 YEL INJ4 INJ4
A3 RED INJ2 INJ2
A4 ORN/WHT VTS VTEC solenoid
A5 LT BLU INJ3 INJ3
A6 ORN/BLK PO2SHTC O2 sensor (heating element)
A7 GRN/YEL FLR1 fuel pump
A8 (empty)
A9 GRN/WHT IACV IAC valve
A10 (empty)
A11 (empty)
A12 YEL/GRN FANC Fan Output
A13 GRN/ORN MIL MIL (check engine light)
A14 (empty)
A15 BLK/RED ACC (a/c compressor clutch)
A16 WHT/YEL ALT C alternator
A17
A18 (empty)
A19 (a/t trans only)
A20 RED PCS EVAP purge control solenoid
A21 RED/GRN ICM ICM
A22 (empty)
A23 BLK PG1 ground
A24 BLK PG2 ground
A25 YEL/BLK IGP2 to main relay and to ground for o
A26 BRN/BLK LG1 ground
B1 YEL/BLK IGP2 to pin A25
B2 BRN/BLK LG2 ground to shields for CYP & TDC
B3 (a/t trans only)
B4 (a/t trans only)
B5 BLU/RED ACS a/c switch
B6 (empty)
B7 (a/t trans only)
B8 BRN/RED PSPSW PSP switch
B9 BLU/WHT clutch interlock switch
B10 YEL/BLU VSS vehicle speed sensor
B11 ORN CYP P CYP -P
B12 WHT CYP M CYP -M
B13 ORN/BLU TDC P TDC -P
B14 WHT/BLU TDC M TDC -M
B15 BLU/GRN CKP P CKP -P
B16 BLU/YEL CKP M CKP -M
D1 WHT/BLU VBU Back Up Power
D2 GRN/WHT BKSW brake switch
D3 KS Knock Sensor
D4 BRN SCS service check connector
D5 (empty)
D6 ORN/BLU VTM VTEC pressure switch
D7 LT BLU TXD/RXD (data link connector)
D8 (empty)
D9 PNK ALT F alternator
D10 GRN/RED ELD electric load detector
D11 RED/BLU TPS TPS Signal
D12 YEL/GRN
D13 RED/WHT ECT ECT sensor
D14 WHT PHO2S O2 sensor
D15 RED/YEL IAT IAT sensor
D16 WHT/YEL VREF VREF
D17 WHT MAP Map Signal
D18 (a/t trans only)
D19 YEL/GRN VCC1 MAP 5V
D20 YEL/WHT VCC2 TPS 5V
D21 GRN/BLU SG1 MAP GND
D22 GRN/WHT SG2 TPS GND
A1 BRN INJ1 INJ1
A2 YEL INJ4 INJ4
A3 RED INJ2 INJ2
A5 LT BLU INJ3 INJ3
A8 (empty)
A10 (empty)
A11 (empty)
A14 (empty)
A17
A18 (empty)
A21 RED/GRN ICM ICM
A22 (empty)
A23 BLK PG1 ground
A24 BLK PG2 ground
B3 (a/t trans only)
B4 (a/t trans only)
B6 (empty)
B7 (a/t trans only)
D3 KS Knock Sensor
D5 (empty)
D8 (empty)
D12 YEL/GRN
onesickej1
Nov 2, 2009 01:56 PM
